0 Replies Latest reply on Jan 6, 2010 11:41 AM by Paul Reilly
    [svn:fx-trunk] 13310: * Fixed some injections from revision 13169 and a few other bugs.
    Paul Reilly Level 1
      Revision: 13310
      Revision: 13310
      Author:   preilly@adobe.com
      Date:     2010-01-06 11:40:51 -0800 (Wed, 06 Jan 2010)
      Log Message:
      • Fixed some injections from revision 13169 and a few other bugs.
      QE notes:
      Doc notes:
      Bugs: SDK-24857, SDK-24873, SDK-23583, SDK-24833
      Reviewer: Corey, Gaurav
      Tests run: checkintests
      Is noteworthy for integration: yes, most of these fixes address issues seen in FB
      Code-level description of changes:
        tools/oem/Application.java
        tools/oem/Library.java
          Modified recompile() to only use the global SWC cache if the value
          of strict hasn't been changed.  This fixes SDK-23583.
        tools/oem/LibraryCache.java
          Updated comment.
        tools/oem/internal/OEMReport.java
          Replaced sourceList variable with just it's paths, which is all we
          really use.  This fixes SDK-24857.
        tools/PreLink.java
          Modified postRun() to disconnect the root's Logger after
          validating it's StyleContainer.  This fixes SDK-24873.
        compiler/Source.java
          Made disconnect() public, so PreLink can call it.
        compiler/as3/binding/ClassInfo.java
          This fixes SDK-24833.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24857
          http://bugs.adobe.com/jira/browse/SDK-24873
          http://bugs.adobe.com/jira/browse/SDK-23583
          http://bugs.adobe.com/jira/browse/SDK-24833
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/ClassInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/LibraryCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
