0 Replies Latest reply on Jan 6, 2010 2:17 PM by Chet Haase
    [svn:fx-trunk] 13315: Fixed a problem with percent constraints being restored properly after effects were run .
    Chet Haase
      Revision: 13315
      Revision: 13315
      Author:   chaase@adobe.com
      Date:     2010-01-06 14:16:48 -0800 (Wed, 06 Jan 2010)
      Log Message:
      Fixed a problem with percent constraints being restored properly after effects were run. The problem was that multi-target effects would apply end values before all instances were done running, so some values would be clobbered. For example, when we reset to percent width, we would sometimes clobber it and set an explicit width again before the other instances ended, thus blowing away the proper constraint value.
      QE notes: None
      Doc notes: None
      Bugs: sdk-24887
      Reviewer: Jason
      Tests run: checkintests, Mustella mx/effects & spark/effects
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-24887
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
