0 Replies Latest reply on Jan 6, 2010 4:19 PM by Chet Haase
    [svn:fx-trunk] 13317: Fix to allow Animate to automatically handle changes in styles during transitions .
    Chet Haase Level 3
      Revision: 13317
      Revision: 13317
      Author:   chaase@adobe.com
      Date:     2010-01-06 16:19:04 -0800 (Wed, 06 Jan 2010)
      Log Message:
      Fix to allow Animate to automatically handle changes in styles during transitions. This same logic already works for properties (e.g., if you specify different values for x in states and run Animate with a SimpleMotionPath with property="x" then it will automatically determine the from/to values to animate for x). But we needed to add an override for getRelevantStyles() for Animate to advertise the possible styles to pick up changes for so that the transitions array would be populated accordingly.
      QE notes: None
      Doc notes: This is a fix that should allow the second animated skin example in the docs (spark_skinning, p46) to work as detailed in my edits
      Bugs: sdk-24932
      Reviewer: Jason
      Tests run: checkintests, Mustella spark/effects
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-24932
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Animate.as
