0 Replies Latest reply on Jan 6, 2010 6:11 PM by mike_morearty
    [svn:fx-trunk] 13319: Fix FB-25101: Application reported as "<unnamed>" in the debugger console.
    mike_morearty Level 1
      Revision: 13319
      Revision: 13319
      Author:   mmoreart@adobe.com
      Date:     2010-01-06 18:11:29 -0800 (Wed, 06 Jan 2010)
      Log Message:
      Fix FB-25101: Application reported as ""  in the debugger console.
      Revert revision 11903, which was supposed to fix SDK-22564: Debug player logs RSL sizes to console using main SWF name.  The underlying issue is a Flash player bug (it is sometimes reports incorrect filenames when loading swfs), and my fix was actually a hack to attempt to work around that issue, but it turns out my hack isn't reliable.  Backing out the hack.  I have logged a separate Flash player bug to fix the real issue.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/FB-25101
          http://bugs.adobe.com/jira/browse/SDK-22564
      Modified Paths:
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/SwfInfo.java
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/DManager.java
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/DSwfInfo.java
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/events/SwfLoadedEvent.java
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/threadsafe/ThreadSafeSwfInf o.java
