0 Replies Latest reply on Jan 6, 2010 9:50 PM by jmurphy67
    [svn:fx-trunk] 13323: Localization property file update 4.0.0.13320
    jmurphy67 Level 1
      Revision: 13323
      Revision: 13323
      Author:   jimurphy@adobe.com
      Date:     2010-01-06 21:50:22 -0800 (Wed, 06 Jan 2010)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/automation/bundles/da_DK/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/de_DE/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/es_ES/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/fi_FI/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/fr_FR/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/it_IT/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/ja_JP/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/ko_KR/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/nb_NO/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/nl_NL/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/pt_BR/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/ru_RU/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/sv_SE/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/zh_CN/automation.properties
          flex/sdk/trunk/frameworks/projects/automation/bundles/zh_TW/automation.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/da_DK/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/de_DE/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/es_ES/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/fi_FI/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/fr_FR/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/it_IT/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ja_JP/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ko_KR/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/nb_NO/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/nl_NL/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/pt_BR/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ru_RU/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/sv_SE/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/zh_CN/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/zh_TW/components.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_da. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_de. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_es. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fi. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fr. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_it. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ja. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ko. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nb. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nl. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_pt. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ru. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_sv. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ TW.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_TW.properties
