2 Replies Latest reply on Jan 7, 2010 7:49 AM by ricky.catano
    ColdFusion8 & Java
    ricky.catano Level 1
      Hi All,
      My ColdFusion 8.0.1 Enterprise Server's jrun.exe is suffering memory leaks. I believe this may have to do with the Java interaction. However, the java on the machine is Java6U12. I noticed though, that in the ColdFusion8\runtime\jre\bin, it has its own java executables. These are Java6U4. I was wondering two things: Does ColdFusion8 not use the machine's Java version, instead using the java in its own directories, and if so, can I update this Java to the newest version in an attempt to correct the memory leaks? Any help at all would be greatly appreciated.
      Thank you.
