0 Replies Latest reply on Jan 7, 2010 8:10 AM by CoreyRLucier
    [svn:fx-trunk] 13325: We' re moving to a new directory structure to support 10.0 and 10. 1 playerglobal.swc living side by side.
    CoreyRLucier Adobe Employee
      Revision: 13325
      Revision: 13325
      Author:   clucier@adobe.com
      Date:     2010-01-07 08:10:12 -0800 (Thu, 07 Jan 2010)
      Log Message:
      We're moving to a new directory structure to support 10.0 and 10.1 playerglobal.swc living side by side. This is a phased approach, just now moving our current playerglobal libs into the new directory format, and updating build files / project files accordingly to accommodate.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Jim
      Tests run: Checkin
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/build.properties
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/development/eclipse/flex/framework/.actionScriptProperties
          flex/sdk/trunk/frameworks/build_framework.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/javascript/build.xml
          flex/sdk/trunk/frameworks/projects/airframework/build.xml
          flex/sdk/trunk/frameworks/projects/airspark/build.xml
          flex/sdk/trunk/frameworks/projects/automation/build.xml
          flex/sdk/trunk/frameworks/projects/automation_dmv/build.xml
          flex/sdk/trunk/frameworks/projects/automation_flashflexkit/build.xml
          flex/sdk/trunk/frameworks/projects/automation_spark/build.xml
          flex/sdk/trunk/frameworks/projects/datavisualization/build.xml
          flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
          flex/sdk/trunk/frameworks/projects/flex/build.xml
          flex/sdk/trunk/frameworks/projects/framework/build.xml
          flex/sdk/trunk/frameworks/projects/halo/build.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/build.xml
          flex/sdk/trunk/frameworks/projects/rpc/build.xml
          flex/sdk/trunk/frameworks/projects/sparkskins/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/wireframe/build.xml
          flex/sdk/trunk/samples/themes/arcade/build.xml
          flex/sdk/trunk/samples/themes/cobalt/build.xml
          flex/sdk/trunk/samples/themes/graphite/build.xml
          flex/sdk/trunk/samples/themes/zen/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/libs/player/10.0/
          flex/sdk/trunk/frameworks/libs/player/10.0/playerglobal.swc
          flex/sdk/trunk/frameworks/libs/player/9.0/
          flex/sdk/trunk/frameworks/libs/player/9.0/playerglobal.swc
      Removed Paths:
          flex/sdk/trunk/frameworks/libs/player/10/
          flex/sdk/trunk/frameworks/libs/player/9/
