0 Replies Latest reply on Jan 7, 2010 9:20 AM by Carol L. Frampton
    [svn:fx-trunk] 13332: TLF Build 587.
    Carol L. Frampton Level 2
      Revision: 13332
      Revision: 13332
      Author:   cframpto@adobe.com
      Date:     2010-01-07 09:20:09 -0800 (Thu, 07 Jan 2010)
      Log Message:
      TLF Build 587.  Release notes stop at build 584 - looks like a couple of changes for composite operations.
      Rearrange samples to match TLF rearrangement.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/spark/.project
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/CompositeO peration.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/FlowOperat ion.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/.actionScriptProperties
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/.actionScriptProperties
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.587.swf
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/src/
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/src/FTEHelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/src/FTEParagraph.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/src/
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/src/Alice.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/src/Pagination.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/src/PaginationWidget.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/ContextMenuText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/CustomImportMarkup.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/CustomLinkEventHandler.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/EditText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/ExplicitFormField.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/HelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/ImportMarkup.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/InlineGraphic.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/LinkedContainers.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/MultipleColumns.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/MultipleContainerColumns.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/ParagraphBorder.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/ParagraphBounds.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/SelectText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/StaticHelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/src/StaticTextFlow.as
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.584.swf
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/FTEHelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/FTE/FTEParagraph.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/Alice.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/Pagination.as
          flex/sdk/trunk/samples/textLayout/actionscript/Pagination/PaginationWidget.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ContextMenuText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/CustomImportMarkup.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/CustomLinkEventHandler.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/EditText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ExplicitFormField.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/HelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ImportMarkup.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/InlineGraphic.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/LinkedContainers.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/MultipleColumns.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/MultipleContainerColumns.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ParagraphBorder.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/ParagraphBounds.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/SelectText.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/StaticHelloWorld.as
          flex/sdk/trunk/samples/textLayout/actionscript/TextLayout/StaticTextFlow.as
