Revision: 13340
Revision: 13340
Author: rfrishbe@adobe.com
Date: 2010-01-07 11:30:18 -0800 (Thu, 07 Jan 2010)
Log Message:
Fixing OSMF RSLs. Now we have a build number in the OSMF RSL that's checked in. There are some other build script changes that need to go along with this change that Jim will be doing. He'll also verify this RSL digest is correct.
QE notes: -
Doc notes: -
Bugs: SDK-24946
Reviewer: Pete
Tests run: checkintests
Is noteworthy for integration: Yes
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24946
Modified Paths:
flex/sdk/trunk/build.xml
flex/sdk/trunk/frameworks/air-config.xml
flex/sdk/trunk/frameworks/flex-config.xml
flex/sdk/trunk/frameworks/libs/osmf.swc
Added Paths:
flex/sdk/trunk/frameworks/rsls/osmf_flex.4.0.0.13104.swf
Removed Paths:
flex/sdk/trunk/frameworks/rsls/osmf_4.0.0.0.swf
