0 Replies Latest reply on Jan 7, 2010 5:11 PM by Peter Farland
    [svn:fx-trunk] 13358: Manually removing extraneous whitespace from the start of the en_US playerglobal rb DITA XML files to unblock the build .
    Peter Farland Level 3
      Revision: 13358
      Revision: 13358
      Author:   pfarland@adobe.com
      Date:     2010-01-07 17:10:34 -0800 (Thu, 07 Jan 2010)
      Log Message:
      Manually removing extraneous whitespace from the start of the en_US playerglobal rb DITA XML files to unblock the build. We need to work with the doc team to make sure future drops do not contain this whitespace.
      QE notes: N/A
      Doc notes: N/A
      Bugs:
      SDK-24896 - playerglobal_rb.swc has dita content that is not encoded correctly
      Reviewer: For Jim, Jeff
      Tests run: ant other.locales
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24896
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/__Global__.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.net.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.update.events.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.update.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/authoring.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.accessibility.xm l
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.data.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.desktop.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.display.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.errors.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.events.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.external.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.filesystem.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.filters.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.geom.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.html.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.media.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.net.drm.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.net.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.printing.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.profiler.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.sampler.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.security.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.system.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.text.engine.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.text.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.ui.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.utils.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.xml.xml
