0 Replies Latest reply on Jan 7, 2010 10:16 PM by Peter Farland
    [svn:fx-trunk] 13366: Ensuring that AFEFontManager, if it is available, overrides the lookup for embedded fonts for all supported font types, including TTF, when embedding legacy DefineFont3 fonts.
    Peter Farland Level 3
      Revision: 13366
      Revision: 13366
      Author:   pfarland@adobe.com
      Date:     2010-01-07 22:15:50 -0800 (Thu, 07 Jan 2010)
      Log Message:
      Ensuring that AFEFontManager, if it is available, overrides the lookup for embedded fonts for all supported font types, including TTF, when embedding legacy DefineFont3 fonts. BatikFontManager will remain a backup in the event that AFEFontManager is not found though BatikFontManager;s support is limited to TTF for legacy DefineFont3 fonts.
      QE notes: Remember that bitmap comparisons could change slightly
      Doc notes: N/A
      Bugs: N/A
      Reviewer: For Gaurav
      Tests run: checkintests, QE had run local tests
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/frameworks/flex-config.xml
