Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Printing and Distribution
Avatar
Level 2
Can someone please answer the following questions on LiveCycle forms
1. Is there a facility to bulk print forms or print forms individually from a management console?
2. Is there anyway to generate an image version of a submiited form.  When an user fills in the data in a form and submits the form I need to take an image of the form, can this be autogenerated?
Arjuna.
1 Accepted Solution
Avatar
Correct answer by
Level 8
1 - LiveCycle Production Print Supported formats
Input
DataXML and field, record, or page-based ASCII data
Preformatted documentsAFP and PDF
Output
DocumentsAFP, IJPDS, PostScript®, and PCL
LabelsZebra, TEC, Printronix, and Intermec
ElectronicPDF, PDF/A, CSV, HTML, XML, TIFF, JPEG, BMP, GIF, and PNG
http://www.adobe.com/products/livecycle/productionprint/
2 - If you are asking if there is a way to both render and convert the PDF in one step then, yes.  You can create a small workflow in the LiveCycle environment and string together multiple operations.  You would do this using the Workbench tool to connect to the LiveCycle server.  The resulting workflow can be called through the API and will do both steps at once.
View solution in original post
Avatar
Level 8
Not sure about a management console, but there are two modules for printing forms.  Output and Production Print.  Which one you use depends on the print run size and some other factors too numerious to discuss here.  The marketing info on the Adobe.com website does a pretty good job of differentiating them.
Yes.  The toImage2 operation (under Common I believe) will convert the PDF to an image.
Avatar
Level 2
Hi Hodmi,
Thanks for your response,
With regards to question 1, what are the print stream formats that are supported by
Adobe LiveCycle Production Print ES2.
With regards to question 2, is there any way for me to set it up so that it automatically saves an image of the document (doesn't it do this by default) rather than calling an API method?
Arjuna.
Avatar
Correct answer by
Level 8
Input
Output
