7 Replies Latest reply on Jan 8, 2010 7:44 AM by Limon26
    global variable not targeting
    Limon26 Level 1
      I am trying to set up a global variable.
      On the root of my timeline, I have this;
      _global.floorVar = "0";
      trace(floorVar);
      which seems to trace fine to say 0.
      Then, inside of a movie clip on the main timeline, I have a button function:
      floor1.onRelease = function() {
      _global.floorVar = "1";
      trace(_global.floorVar)
      _root.gotoAndStop(2);
      if (_global.floorVar == 1) {
      trace("it works");
      It traces as 1 once I press the button, but the if statement doesn't trace "it works"
      is my global variable set up wrong?
        • 1. Re: global variable not targeting
          RossRitchey Level 4
          You global variable is set up as a string, so the if statement needs to check for "1" and not 1.
          If you want the var to be a number remove the quotes from around it when you set it:
          _global.floorVar = 0;
          • 2. Re: global variable not targeting
            Limon26 Level 1
            I removed the all the quotes so when I call it I say:
            The if statement is:
                 trace("sweet");
            And the button function is:
                 _global.floorVar = 1;
            Is that set up correctly now?
            The if statement is still not tracing "sweet" when the button is pressed to set it as 1?
            • 3. Re: global variable not targeting
              RossRitchey Level 4
              Where is the if statement located?
              • 4. Re: global variable not targeting
                Limon26 Level 1
                The root timeline is where the global variable is declared
                Inside of a movie clip on the main timeline is where the
                Button function is and the if statement is right under the button function.
                • 5. Re: global variable not targeting
                  Rothrock Level 5
                  Where is your if statement. From how it looks here it is something that is just going to execute once, probably right after the _global variable is first defined. If statements don't just hang around and wait until the variable changes.
                  You can add a trace,
                       trace("sweet");
                  } else {
                       trace("Darn, at this point floorVar is: "+_gobal.floorVar);
                  I imagine you will see that trace just once and its value will be zero.
                  If you want to keep checking you can use an enterframe:
                  this.onEnterFrame=function(){
                  if(_global.floorVar == 1){
                  trace("sweet");
                  delete this.onEnterFrame;
                  Of course depending upon what you are doing that may or may not be a good way of doing it. There is also the ability to watch() a variable and have a function called anytime the variable is changed—the equivalent of a getter/setter. I don't think I've used it with _global, but I think it should work. Of course _global variables aren't generally good practice....
                  • 6. Re: global variable not targeting
                    Limon26 Level 1
                    Ok, I just moved the if statement within the button function and it works.
                    So is there a better way to do this or a way to combine all the button functions somehow?
                    I have a bunch of button functions that look like this, but the if statement is going to start getting long because there are a bunch of floors that I need to check for:
                    floor6.onRelease = function() {
                         _global.floorVar = 6;
                         _root.gotoAndStop(4);
                         do this
                    } else {
                         Do this stuff
                    Thanks!
                    • 7. Re: global variable not targeting
                      RossRitchey Level 4
                      You can move that if statement to a separate function:
                           _root.checkFloor();
                      function checkFloor(){
                                do this
                           } else {
                                Do this stuff
                      Though, at the same time - if each button press sends to a specific floor, and you are doing something specific for each floor, you can simply put that code in the button press function:
                           //Do the Floor 6 specific stuff//
