3 Replies Latest reply on Jan 14, 2010 12:04 PM by terrjack
    Acrobat Reader 9.2 will not install, hangs after 1st launch OSX
    terry-jackson
      I have an imac, running OSX 10.5.8 Leopard.
      I tried downloading and installing the Adobe Reader 9 software
      under the Admin account, and wehn launched,
      it shows the "Install/Fixing Installation" screen,
      and after 20 mins does nothing, and I have to force quit.
      I tried trashing the Adobe Reader9 folder, and redownloading
      the installer again, and then try to install it again from
      the installer. Again, same thing, won't install.
      If I go back to the Adobe.com website and install the
      Acrobat 8.1.3 software, it installs fine  without a hitch.
      So what is hanging in the Adobe 9 software that is causing an issue?
      Someone told me that Acrobat 9 is tied to Adobe Air, is this the problem?
        • 1. Re: Acrobat Reader 9.2 will not install, hangs after 1st launch OSX
          MichaelKazlow MVP & Adobe Community Professional
          Could be. Try downloading and installing the latest version of AIR and see what happens.
          • 2. Re: Acrobat Reader 9.2 will not install, hangs after 1st launch OSX
            HeinzFretterlech
            I have a similar problem with my Macbook running Mac OS 10.4.
            My installed Adobe-reader tries to update everytime i open a pdf-document via my browser (safari). When I trie to update it, it gives me an error-message. I don't know how to fix it. For example when i trie to download a pdf-document on http://www.neurodermitisportal.de . Hope you'll help me, thank you very much!
            • 3. Re: Acrobat Reader 9.2 will not install, hangs after 1st launch OSX
              terrjack
              I tried downloading Adobe Air seperate, installing it first, and then tried to install Acrobat reader.
              No Go, it sits there with a BeachBall and a blank window for 20 minutes before I give up and force quit.
              I then get the "Send to Apple" window to report the error.
              Here is what the error log says:
              Date/Time:       2010-01-14 13:48:20 -0500
              OS Version:      10.6.2 (Build 10C540)
              Architecture:    x86_64
              Report Version:  6
              Command:         Adobe Reader
              Path:            /Applications/Adobe Reader 9/Adobe Reader.app/Contents/MacOS/AdobeReader
              Version:         9.3.0 (9.3.0)
              Parent:          launchd [90]
              PID:             241
              Event:           hang
              Duration:        6.22s (sampling started after 2 seconds)
              Steps:           42 (100ms sampling interval)
              Pageins:         24
              Pageouts:        0
              Process:         AdobeReader [241]
              UID:             501
              Process:         Adobe AIR Application Installer [259]
              Path:            /Applications/Adobe Reader 9/Adobe Reader.app/Contents/MacOS/AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
              UID:             0
              Process:         Adobe AIR Installer [258]
              Path:            /Applications/Adobe Reader 9/Adobe Reader.app/Contents/MacOS/AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
              UID:             0
              Process:         AirPort Base Station Agent [120]
              Path:            /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
              UID:             501
                Thread 9846000    DispatchQueue 1
                User stack:
                  42 ??? (in AirPort Base Station Agent + 5344) [0x1000014e0]
                    42 ??? (in AirPort Base Station Agent + 70666) [0x10001140a]
                      42 CFRunLoopRun + 70 (in CoreFoundation) [0x7fff86dae9b6]
                        42 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff86daec2f]
                          42 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff86daf7a2]
                            42 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff80217e3a]
                Kernel stack:
                  42 ipc_mqueue_receive_continue + 0 [0x210aa3]
                Thread 987e7a8    DispatchQueue 2
                User stack:
                  42 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff80231a55]
                    42 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff80231bb8]
                      42 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x7fff80232286]
                        42 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff8023275c]
                          42 kevent + 10 (in libSystem.B.dylib) [0x7fff80230bba]
                Kernel stack:
                  42 kevent + 97 [0x471745]
                Thread 98f4000
                User stack:
                  42 thread_start + 13 (in libSystem.B.dylib) [0x7fff80250e41]
                    42 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff80250f8e]
                      42 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x7fff8025b9e2]
                Kernel stack:
                  42 sleep + 52 [0x487f93]
                Binary Images:
                       0x100000000 -        0x100016fff  com.apple.AirPortBaseStationAgent 1.5.4 (154.2) <73DF13C1-AF86-EC2C-9056-8D1946E607CF> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
                    0x7fff80217000 -     0x7fff803d5ff7  libSystem.B.dylib ??? (???) <526DD3E5-2A8B-4512-ED97-01B832369959> /usr/lib/libSystem.B.dylib
                    0x7fff86d64000 -     0x7fff86ed7ff7  com.apple.CoreFoundation 6.6.1 (550.13) <1E952BD9-37C6-16BE-B2F0-CD92A6283D37> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
              Process:         AppleVNCServer [123]
              Path:            /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/MacOS/AppleV NCServer
              UID:             501
                Thread 98f4b7c    DispatchQueue 1
                User stack:
                  42 ??? (in AppleVNCServer + 5220) [0x100001464]
                    42 ??? (in AppleVNCServer + 6677) [0x100001a15]
                      42 ??? (in AppleVNCServer + 19068) [0x100004a7c]
                Kernel stack:
                Thread 98fe7a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 98fe000
                User stack:
                      42 PrivateMPEntryPoint + 63 (in CarbonCore) [0x7fff8694fb4d]
                Kernel stack:
                Thread 98fe3d4
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100050fe7  com.apple.AppleVNCServer 3.3.2 (3.3.2) <7FBD0348-AAF7-BD03-C83A-70B181F0ED12> /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/MacOS/AppleV NCServer
                    0x7fff86949000 -     0x7fff86c7bfef  com.apple.CoreServices.CarbonCore 861.2 (861.2) <39F3B259-AC2A-792B-ECFE-4F3E72F2D1A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
              Process:         ARDAgent [115]
              Path:            /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
              UID:             501
                Thread 96b33d4    DispatchQueue 1
                User stack:
                  42 ??? (in ARDAgent + 6944) [0x100001b20]
                    42 ??? (in ARDAgent + 7315) [0x100001c93]
                Kernel stack:
                Thread 98777a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 9863000
                User stack:
                Kernel stack:
                Thread 98e8000
                User stack:
                        42 __wait4 + 10 (in libSystem.B.dylib) [0x7fff80266022]
                Kernel stack:
                Thread 98e87a8
                User stack:
                        42 recvfrom + 10 (in libSystem.B.dylib) [0x7fff8025ba06]
                Kernel stack:
                  42 lo64_unix_scall + 77 [0x29e3fd]
                    42 unix_syscall64 + 617 [0x4ee947]
                      42 recvfrom_nocancel + 325 [0x4b5be9]
                        42 shutdown + 501 [0x4b5443]
                          42 soreceive + 1134 [0x4b01ab]
                            42 sbwait + 150 [0x4b22a7]
                              42 msleep + 157 [0x4882d6]
                                42 wakeup + 334 [0x487be3]
                                  42 lck_mtx_sleep + 87 [0x2217b0]
                                    42 thread_block + 33 [0x226fb5]
                                      42 thread_block_reason + 331 [0x226f27]
                                        42 thread_dispatch + 1950 [0x226c88]
                                          42 machine_switch_context + 753 [0x2a5a37]
                Binary Images:
                       0x100000000 -        0x1000d1ff7  com.apple.RemoteDesktopAgent 3.3.2 (3.3.2) <39BD5CB7-A117-FCB7-27FB-26DE49CEA87E> /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
              Process:         autofsd [43]
              Path:            /usr/libexec/autofsd
              UID:             0
                Thread 8731b7c    DispatchQueue 1
                User stack:
                  42 ??? (in autofsd + 5340) [0x1000014dc]
                    42 ??? (in autofsd + 6461) [0x10000193d]
                Kernel stack:
                Thread 878a7a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100001ff7  autofsd ??? (???) <29276FAC-AEA8-1520-5329-C75F9D453D6C> /usr/libexec/autofsd
              Process:         blued [42]
              Path:            /usr/sbin/blued
              UID:             0
                Thread 871e000    DispatchQueue 1
                User stack:
                  42 ??? (in blued + 5016) [0x100001398]
                    42 ??? (in blued + 152265) [0x1000252c9]
                      42 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation) [0x7fff84e53903]
                        42 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x7fff84e53a24]
                Kernel stack:
                Thread 8a7ab7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 8fae000
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100044fff  blued ??? (???) <ECD752C9-F98E-3052-26BF-DC748281C992> /usr/sbin/blued
                    0x7fff84e08000 -     0x7fff85089fe7  com.apple.Foundation 6.6.1 (751.14) <767349DB-C486-70E8-7970-F13DB4CDAF37> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
              Process:         CCacheServer [122]
              Path:            /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer
              UID:             501
                Thread 870c7a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 93d6000    DispatchQueue 6
                User stack:
                      42 _dispatch_worker_thread2 + 231 (in libSystem.B.dylib) [0x7fff80232279]
                        42 __sigsuspend_nocancel + 10 (in libSystem.B.dylib) [0x7fff8028afca]
                Kernel stack:
                Binary Images:
              Process:         configd [13]
              Path:            /usr/libexec/configd
              UID:             0
                Thread 807db7c    DispatchQueue 1
                User stack:
                  42 start + 52 (in configd) [0x100001488]
                    42 main + 2051 (in configd) [0x100001c9e]
                      42 server_loop + 72 (in configd) [0x1000024f4]
                Kernel stack:
                Thread 81b2b7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 804c7a8
                User stack:
                      42 plugin_exec + 1440 (in configd) [0x100003c5b]
                Kernel stack:
                Thread 8635b7c
                User stack:
                      42 _io_pm_force_active_settings + 2266 (in PowerManagement) [0x10050f968]
                Kernel stack:
                Thread 865b000
                User stack:
                Kernel stack:
                Thread d428b7c
                User stack:
                    42 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff802319da]
                Kernel stack:
                  42 workqueue_thread_yielded + 562 [0x4cb6ae]
                Binary Images:
                       0x100000000 -        0x100026ff7  configd ??? (???) <58C02CBA-5556-4CDC-2763-814C4C7175DE> /usr/libexec/configd
                       0x10050c000 -        0x10051dfff  com.apple.SystemConfiguration.PowerManagement 160.0.0 (160.0.0) <0AC3D2ED-919E-29C7-9EEF-629FBDDA6159> /System/Library/SystemConfiguration/PowerManagement.bundle/Contents/MacOS/PowerManagement
              Process:         coreaudiod [78]
              Path:            /usr/sbin/coreaudiod
              UID:             202
                Thread 86353d4    DispatchQueue 1
                User stack:
                  42 ??? (in coreaudiod + 3252) [0x100000cb4]
                    42 ??? (in coreaudiod + 26505) [0x100006789]
                Kernel stack:
                Thread 9357b7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread d4283d4
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x10001ffef  coreaudiod ??? (???) <A060D20F-A6A7-A3AE-84EC-11D7D7DDEBC6> /usr/sbin/coreaudiod
              Process:         coreservicesd [53]
              Path:            /System/Library/CoreServices/coreservicesd
              UID:             0
                Thread 891d7a8    DispatchQueue 1
                User stack:
                  42 ??? (in coreservicesd + 3756) [0x100000eac]
                    42 _CoreServicesServerMain + 522 (in CarbonCore) [0x7fff869f8972]
                Kernel stack:
                Thread 89d6b7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 89d6000
                User stack:
                      42 fmodWatchConsumer + 347 (in CarbonCore) [0x7fff869ad23f]
                        42 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff802529ee]
                Kernel stack:
                  42 semaphore_wait_continue + 0 [0x22a0a5]
                Thread 89dfb7c
                User stack:
                      42 read + 10 (in libSystem.B.dylib) [0x7fff80222426]
                Kernel stack:
                      42 read_nocancel + 158 [0x496add]
                        42 write + 312 [0x49634d]
                          42 get_pathbuff + 3054 [0x3023db]
                            42 tsleep + 105 [0x4881ce]
                              42 wakeup + 786 [0x487da7]
                Thread 8a7a7a8
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100000fff  coreservicesd ??? (???) <D804E55B-4376-998C-AA25-2ADBFDD24414> /System/Library/CoreServices/coreservicesd
              Process:         cvmsComp_x86_64 [69]
              Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_x86_64
              UID:             212
                Thread 883eb7c    DispatchQueue 1
                User stack:
                  42 ??? (in cvmsComp_x86_64 + 2740) [0x100000ab4]
                    42 llvm::CVMSMemoryManager::getDlsymTable() const + 3295 (in cvmsComp_x86_64) [0x1000035ed]
                      42 mach_msg_server + 539 (in libSystem.B.dylib) [0x7fff8029518e]
                        42 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x7fff80217e46]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100005ff7  cvmsComp_x86_64 ??? (???) <00A29B78-A800-DF69-8C10-6E2BAF75F260> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_x86_64
              Process:         cvmsServ [65]
              Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
              UID:             0
                Thread 87c5b7c    DispatchQueue 1
                User stack:
                  42 ??? (in cvmsServ + 4100) [0x100001004]
                    42 ??? (in cvmsServ + 23081) [0x100005a29]
                Kernel stack:
                Thread 86dd7a8
                User stack:
                      42 ??? (in cvmsServ + 16132) [0x100003f04]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100008fff  cvmsServ ??? (???) <6200AD80-4159-5656-8736-B72B7388C461> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
              Process:         DirectoryService [15]
              Path:            /usr/sbin/DirectoryService
              UID:             0
                Thread 85cb000    DispatchQueue 1
                User stack:
                  42 start + 52 (in DirectoryService) [0x10000da74]
                    42 main + 3086 (in DirectoryService) [0x10000e68a]
                Kernel stack:
                Thread 8635000    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 86357a8    DispatchQueue 6
                User stack:
                        42 _dispatch_call_block_and_release + 15 (in libSystem.B.dylib) [0x7fff80253ce8]
                          42 syscall + 10 (in libSystem.B.dylib) [0x7fff802542da]
                Kernel stack:
                Thread 8648b7c
                User stack:
                      42 DSLThread::_RunWrapper(void*) + 67 (in DirectoryServiceCore) [0x10017834b]
                        42 DSCThread::Run() + 36 (in DirectoryServiceCore) [0x1001780ac]
                          42 CPluginRunLoopThread::ThreadMain() + 150 (in DirectoryService) [0x10001d224]
                Kernel stack:
                Thread 9877b7c
                User stack:
                Kernel stack:
                Thread 98feb7c
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100120fff  DirectoryService ??? (???) <493053C4-CC96-BD73-69D4-85250B2FBC6F> /usr/sbin/DirectoryService
                       0x100170000 -        0x100181fff  com.apple.DirectoryServiceCore.Framework 3.6 (621.1) <8D337B0E-9E06-1829-2AC9-21929325488B> /System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServ iceCore
              Process:         diskarbitrationd [12]
              Path:            /usr/sbin/diskarbitrationd
              UID:             0
                Thread 809eb7c    DispatchQueue 1
                User stack:
                  42 ??? (in diskarbitrationd + 4064) [0x100000fe0]
                    42 ??? (in diskarbitrationd + 32876) [0x10000806c]
                Kernel stack:
                Thread 81b23d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 987e3d4
                User stack:
                  5 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff80231a55]
                    5 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff802319da]
                Kernel stack:
                  5 workqueue_thread_yielded + 562 [0x4cb6ae]
                Binary Images:
                       0x100000000 -        0x10001bfef  diskarbitrationd ??? (???) <E59D4CB3-3CC5-03AD-DE45-91F98CC6B2F2> /usr/sbin/diskarbitrationd
              Process:         distnoted [16]
              Path:            /usr/sbin/distnoted
              UID:             1
                Thread 86487a8    DispatchQueue 1
                User stack:
                  42 ??? (in distnoted + 3620) [0x100000e24]
                    42 ??? (in distnoted + 3717) [0x100000e85]
                Kernel stack:
                Thread 865ab7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 98f43d4
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100000fff  distnoted ??? (???) <EE257B76-1C20-2D83-6441-B6417788ABD9> /usr/sbin/distnoted
              Process:         Dock [94]
              Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
              UID:             501
                Thread 88fd3d4    DispatchQueue 1
                User stack:
                  42 ??? (in Dock + 17796) [0x100004584]
                    42 ??? (in Dock + 18892) [0x1000049cc]
                        42 __CFRunLoopRun + 5201 (in CoreFoundation) [0x7fff86db0551]
                          42 mshPerform + 11 (in HIServices) [0x7fff8108d6b1]
                            42 ??? (in Dock + 89940) [0x100015f54]
                              42 ??? (in Dock + 90530) [0x1000161a2]
                                42 ??? (in Dock + 138385) [0x100021c91]
                                  42 ??? (in Dock + 516118) [0x10007e016]
                                    42 ??? (in Dock + 379245) [0x10005c96d]
                                      42 ??? (in Dock + 383189) [0x10005d8d5]
                                        42 ??? (in Dock + 384878) [0x10005df6e]
                                          42 _HandlePopUpMenuSelection7 + 665 (in HIToolbox) [0x7fff83df076f]
                                            42 PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1651 (in HIToolbox) [0x7fff83df047c]
                                              40 TrackMenuCommon(MenuSelectData&, unsigned char*) + 3355 (in HIToolbox) [0x7fff83ccc9dc]
                                                40 IsUserStillTracking(MenuSelectData*, unsigned char*) + 175 (in HIToolbox) [0x7fff83cdfcd1]
                                                  40 ReceiveNextEventCommon + 310 (in HIToolbox) [0x7fff83c95853]
                                                    40 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff83c95a4e]
                                                      40 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff86daec2f]
                                                        40 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff86daf7a2]
                                                          40 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff80217e3a]
                                              2 TrackMenuCommon(MenuSelectData&, unsigned char*) + 3460 (in HIToolbox) [0x7fff83ccca45]
                                                1 SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 474 (in HIToolbox) [0x7fff83ce54aa]
                                                  1 FlashFeedback(MenuSelectData*) + 131 (in HIToolbox) [0x7fff83ce56eb]
                                                    1 HIView::SimulateClick(short, unsigned int, short*) + 167 (in HIToolbox) [0x7fff83ce57f3]
                                                      1 SendEventToEventTargetWithOptions + 51 (in HIToolbox) [0x7fff83c6df97]
                                                        1 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 395 (in HIToolbox) [0x7fff83c6e126]
                                                          1 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1002 (in HIToolbox) [0x7fff83c6ebd7]
                                                            1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1700 (in HIToolbox) [0x7fff83c7fa00]
                                                              1 HIView::SimulateClickSelf(short, unsigned int, short*) + 94 (in HIToolbox) [0x7fff83ce590c]
        1 SendControlSimulateHit(HIView*, short, unsigned int, short*) + 150 (in HIToolbox) [0x7fff83ce5a54]
        1 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1842 (in HIToolbox) [0x7fff83c7fa8e]
        1 HIStandardMenuView::SimulateHitSelf(short, unsigned int, short*) + 188 (in HIToolbox) [0x7fff83ce5b56]
        1 HIMenuView::SimulateHitSelf(short, unsigned int, short*) + 160 (in HIToolbox) [0x7fff83ce5c4a]
        1 RunCurrentEventLoopInMode + 234 (in HIToolbox) [0x7fff83c959eb]
        1 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff86daec2f]
        1 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff86daf7a2]
        1 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff80217e3a]
                                                1 SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 839 (in HIToolbox) [0x7fff83ce5617]
                                                  1 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff83c95a4e]
                Kernel stack:
                Thread 8fadb7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 9726000
                User stack:
                      42 ??? (in Dock + 88219) [0x10001589b]
                Kernel stack:
                Thread 870c000
                User stack:
                  13 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff80231a55]
                    13 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff802319da]
                Kernel stack:
                  13 workqueue_thread_yielded + 562 [0x4cb6ae]
                Binary Images:
                       0x100000000 -        0x100171fff  com.apple.dock 1.7 (758) <8D023535-D5CF-D81C-8E4D-11C1C92451C2> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                    0x7fff81055000 -     0x7fff810a6fe7  com.apple.HIServices 1.8.0 (???) <113EEB8A-8EC6-9F86-EF46-4BA5C2CBF77C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                    0x7fff83c67000 -     0x7fff83f65fe7  com.apple.HIToolbox 1.6.2 (???) <D463A388-244E-047A-E49A-4DA6C15BD1BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
              Process:         dynamic_pager [37]
              Path:            /sbin/dynamic_pager
              UID:             0
                Thread 870c3d4    DispatchQueue 1
                User stack:
                  42 ??? [0x1000013ec]
                    42 ??? [0x1000023eb]
                      42 ??? [0x100001cae]
                        42 ??? [0x100001a30]
                          42 ??? [0x10000198f]
                            42 ??? [0x7fff80217e3a]
                Kernel stack:
              Process:         Finder [96]
              Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
              UID:             501
                Thread 8a7a3d4    DispatchQueue 1
                User stack:
                  42 ??? (in Finder + 23776) [0x100005ce0]
                    42 ??? (in Finder + 23837) [0x100005d1d]
                      42 NSApplicationMain + 364 (in AppKit) [0x7fff803ec468]
                        42 -[NSApplication run] + 395 (in AppKit) [0x7fff803f3747]
                          42 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x7fff8042db41]
                            42 _DPSNextEvent + 708 (in AppKit) [0x7fff8042e1f2]
                              42 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x7fff83c9570c]
                                42 ReceiveNextEventCommon + 310 (in HIToolbox) [0x7fff83c95853]
                                  42 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff83c95a4e]
                Kernel stack:
                Thread 87313d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 87c53d4
                User stack:
                        42 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 514 (in DesktopServicesPriv) [0x7fff815c8d86]
                Kernel stack:
                Thread 88fdb7c
                User stack:
                Kernel stack:
                Thread 96187a8
                User stack:
                Kernel stack:
                Thread 98f47a8
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x1003aafe7  com.apple.finder 10.6.2 (10.6.2) <5FC801AA-3AEC-F9D6-6EDC-A4D0F708E490> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
                    0x7fff803ea000 -     0x7fff80ddefff  com.apple.AppKit 6.6.3 (1038.25) <2F7A5AC8-29E7-9B5F-D3F1-4C7F5821BB80> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff815c7000 -     0x7fff816abfff  com.apple.DesktopServices 1.5.3 (1.5.3) <F443ED58-3761-116F-A8B2-C6DC29B7D119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
              Process:         fontd [107]
              Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
              UID:             501
                Thread 8fafb7c    DispatchQueue 1
                User stack:
                  42 ??? (in fontd + 16156) [0x100003f1c]
                    42 main_handler + 3919 (in libATSServer.dylib) [0x7fff8408b646]
                Kernel stack:
                Thread 86dd000    DispatchQueue 2
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100003fff  fontd ??? (???) <CE2B0453-8ABF-D809-6F98-32F2D6685922> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                    0x7fff84002000 -     0x7fff840b6fff  libATSServer.dylib ??? (???) <F065A2A1-73A6-7CC2-C564-25D8398A641B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libATSServer.dylib
              Process:         fseventsd [35]
              Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
              UID:             0
                Thread 870cb7c    DispatchQueue 1
                User stack:
                  42 ??? (in fseventsd + 5572) [0x1000015c4]
                    42 ??? (in fseventsd + 8776) [0x100002248]
                      42 mach_msg_server + 597 (in libSystem.B.dylib) [0x7fff802951c8]
                Kernel stack:
                Thread 886c7a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 87317a8
                User stack:
                      42 ??? (in fseventsd + 28948) [0x100007114]
                Kernel stack:
                Thread 878a000
                User stack:
                Kernel stack:
                Thread 883e000
                User stack:
                Kernel stack:
                Thread 883e3d4
                User stack:
                      42 ??? (in fseventsd + 26011) [0x10000659b]
                Kernel stack:
                Thread 883e7a8
                User stack:
                      42 ??? (in fseventsd + 39173) [0x100009905]
                        42 ??? (in fseventsd + 38428) [0x10000961c]
                Kernel stack:
                Thread 886cb7c
                User stack:
                Kernel stack:
                Thread 891d3d4
                User stack:
                Kernel stack:
                Thread 8facb7c
                User stack:
                Kernel stack:
                Thread 9357000
                User stack:
                Kernel stack:
                Thread 99283d4
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x10000ffff  fseventsd ??? (???) <FBB97819-5C10-2C3D-63C0-7D9569A94ED1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
              Process:         hidd [34]
              Path:            /usr/libexec/hidd
              UID:             0
                Thread 86fc000    DispatchQueue 1
                User stack:
                  42 ??? (in hidd + 3756) [0x100000eac]
                    42 ??? (in hidd + 3822) [0x100000eee]
                Kernel stack:
                Thread 865a7a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 86f27a8
                User stack:
                Kernel stack:
                Thread 89093d4
                User stack:
                      42 __IOHIDSessionStartOnThread + 460 (in IOKit) [0x7fff83367b63]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100000fff  hidd ??? (???) <AB950B9C-2A8F-9549-CD2B-15887282443E> /usr/libexec/hidd
                    0x7fff8333e000 -     0x7fff8339bfef  com.apple.framework.IOKit 2.0 (???) <EBBEED67-D5BE-5F7F-96F4-9023BBA1B913> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
              Process:         KernelEventAgent [32]
              Path:            /usr/sbin/KernelEventAgent
              UID:             0
                Thread 86fc7a8    DispatchQueue 1
                User stack:
                  42 start + 52 (in KernelEventAgent) [0x100001174]
                    42 main + 1130 (in KernelEventAgent) [0x1000030aa]
                Kernel stack:
                Thread 878ab7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 8731000
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100006ff7  KernelEventAgent ??? (???) <20952F40-244C-DE8B-B7BA-05B8118647CF> /usr/sbin/KernelEventAgent
              Process:         kextd [10]
              Path:            /usr/libexec/kextd
              UID:             0
                Thread 809e3d4    DispatchQueue 1
                User stack:
                  42 ??? (in kextd + 5608) [0x1000015e8]
                    42 ??? (in kextd + 9541) [0x100002545]
                Kernel stack:
                Thread 81b27a8    DispatchQueue 2
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x10001afff  kextd ??? (???) <E8C384D5-F62D-F608-507B-C658137806C1> /usr/libexec/kextd
              Process:         launchd [1]
              Path:            /sbin/launchd
              UID:             0
                Thread 80857a8    DispatchQueue 1
                User stack:
                  42 start + 52 (in launchd) [0x100001828]
                    42 main + 1841 (in launchd) [0x100007c3c]
                      42 launchd_runtime + 450 (in launchd) [0x10000b653]
                Kernel stack:
                Thread 807a7a8
                User stack:
                Kernel stack:
                Thread 809b7a8
                User stack:
                      42 update_thread + 22 (in launchd) [0x100007d3a]
                        42 sleep + 61 (in libSystem.B.dylib) [0x7fff802a0090]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100029fe7  launchd ??? (???) <AED4A707-E3DE-4836-9343-90D184AF0438> /sbin/launchd
              Process:         launchd [66]
              Path:            /sbin/launchd
              UID:             212
                Thread 8909000    DispatchQueue 1
                User stack:
                Kernel stack:
                Thread 807f3d4
                User stack:
                Kernel stack:
                Binary Images:
              Process:         launchd [90]
              Path:            /sbin/launchd
              UID:             501
                Thread 87ad3d4    DispatchQueue 1
                User stack:
                Kernel stack:
                Thread 9393000
                User stack:
                Kernel stack:
                Binary Images:
              Process:         loginwindow [31]
              Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
              UID:             501
                Thread 86fcb7c    DispatchQueue 1
                User stack:
                  42 ??? (in loginwindow + 18536) [0x100004868]
                    42 ??? (in loginwindow + 19966) [0x100004dfe]
                Kernel stack:
                Thread 8fab3d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100077fef  com.apple.loginwindow 6.0 (6.0) <34D7A56E-DE5D-2C29-5328-CB913034CEFC> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
              Process:         mDNSResponder [30]
              Path:            /usr/sbin/mDNSResponder
              UID:             65
                Thread 86f2000    DispatchQueue 1
                User stack:
                  42 start + 33 (in mDNSResponder) [0x10003086d]
                    42 _start + 224 (in mDNSResponder) [0x100001756]
                      42 main + 2910 (in mDNSResponder) [0x1000022c4]
                Kernel stack:
                Thread 86cc3d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 88fd000
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100063ff7  mDNSResponder ??? (???) <D807168F-8A40-623E-AF8A-15F4F7C761AA> /usr/sbin/mDNSResponder
              Process:         mds [29]
              Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
              UID:             0
                Thread 86f23d4    DispatchQueue 1
                User stack:
                  42 ??? (in mds + 16520) [0x100004088]
                    42 ??? (in mds + 48306) [0x10000bcb2]
                Kernel stack:
                Thread 8faf3d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 87ad000
                User stack:
                Kernel stack:
                Thread 9393b7c
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x1000cbff7  mds ??? (???) <254A5377-0E56-0079-6F5B-9A0E4AE1F008> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
              Process:         mdworker [247]
              Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
              UID:             89
              Note:            Exited before symbolication
                Thread 96f6000    DispatchQueue 1
                User stack:
                  37 ??? [0x100001034]
                    37 ??? [0x1000083ad]
                      37 ??? [0x7fff86dae9b6]
                        37 ??? [0x7fff86daec2f]
                          37 ??? [0x7fff86daf7a2]
                            37 ??? [0x7fff80217e3a]
                Kernel stack:
                  37 ipc_mqueue_receive_continue + 0 [0x210aa3]
                Thread 98467a8    DispatchQueue 2
                User stack:
                  37 ??? [0x7fff80231a55]
                    37 ??? [0x7fff80231bb8]
                      37 ??? [0x7fff80232286]
                        37 ??? [0x7fff8023275c]
                          37 ??? [0x7fff80230bba]
                Kernel stack:
                  37 kevent + 97 [0x471745]
                Thread 987e3d4
                User stack:
                  37 ??? [0x7fff80250e41]
                    37 ??? [0x7fff80250f8e]
                      37 ??? [0x10000a1ad]
                        37 ??? [0x10000a528]
                Kernel stack:
              Process:         mdworker [238]
              UID:             501
                Thread 96f67a8    DispatchQueue 1
                User stack:
                  42 ??? (in mdworker + 4148) [0x100001034]
                    42 ??? (in mdworker + 33709) [0x1000083ad]
                Kernel stack:
                Thread 807d000    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 88767a8
                User stack:
                      42 ??? (in mdworker + 41389) [0x10000a1ad]
                        42 ??? (in mdworker + 42280) [0x10000a528]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x10003bff7  mdworker ??? (???) <07400053-FC07-485E-F2B7-F3B4C93169BB> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
              Process:         notifyd [11]
              Path:            /usr/sbin/notifyd
              UID:             0
                Thread 809e7a8    DispatchQueue 1
                User stack:
                  42 ??? [0x100000758]
                    42 ??? [0x100001c67]
                      42 ??? [0x7fff80230bba]
                Kernel stack:
                Thread 807a3d4
                User stack:
                  42 ??? [0x7fff80250e41]
                    42 ??? [0x7fff80250f8e]
                      42 ??? [0x100001e7e]
                Kernel stack:
              Process:         ntpd [20]
              Path:            /usr/sbin/ntpd
              UID:             0
                Thread 86483d4    DispatchQueue 1
                User stack:
                  42 ??? (in ntpd + 6356) [0x1000018d4]
                    42 ??? (in ntpd + 36998) [0x100009086]
                      42 __sigsuspend + 10 (in libSystem.B.dylib) [0x7fff80277e7a]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100056fef  ntpd ??? (???) <3BCDB850-F8F7-CF24-9E18-61AAE7668E14> /usr/sbin/ntpd
              Process:         ocspd [178]
              Path:            /usr/sbin/ocspd
              UID:             0
                Thread 87c47a8    DispatchQueue 1
                User stack:
                  42 ??? (in ocspd + 5776) [0x100001690]
                    42 ??? (in ocspd + 12007) [0x100002ee7]
                      42 ??? (in ocspd + 86379) [0x10001516b]
                        42 ??? (in ocspd + 85665) [0x100014ea1]
                Kernel stack:
                Thread 8648000    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 8fac7a8
                User stack:
                Kernel stack:
                Thread 98467a8
                User stack:
                  1 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff80231a55]
                    1 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff802319da]
                Kernel stack:
                  1 workqueue_thread_yielded + 562 [0x4cb6ae]
                Binary Images:
                       0x100000000 -        0x100038fff  ocspd ??? (???) <379B154D-225B-D579-FAE3-E857757948EA> /usr/sbin/ocspd
              Process:         pboard [100]
              Path:            /usr/sbin/pboard
              UID:             501
                Thread 8fab000    DispatchQueue 1
                User stack:
                  42 ??? (in pboard + 5860) [0x1000016e4]
                    42 ??? (in pboard + 6062) [0x1000017ae]
                      42 mach_msg_server + 468 (in libSystem.B.dylib) [0x7fff80295147]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100001fff  pboard ??? (???) <2B1550DB-E604-C592-07E9-944CFB25738A> /usr/sbin/pboard
              Process:         RFBRegisterMDNS [27]
              Path:            /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/Support/RFBR egisterMDNS
              UID:             0
                Thread 86f2b7c    DispatchQueue 1
                User stack:
                  42 ??? (in RFBRegisterMDNS + 4836) [0x1000012e4]
                Kernel stack:
                Thread 89d63d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100002ff7  RFBRegisterMDNS ??? (???) <DF9E8CCF-735B-0875-AAB7-CD6A834CEBD0> /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/Support/RFBR egisterMDNS
              Process:         SecurityAgent [136]
              Path:            /System/Library/CoreServices/SecurityAgent.app/Contents/MacOS/SecurityAgent
              UID:             92
                Thread 87adb7c    DispatchQueue 1
                User stack:
                  42 ??? (in SecurityAgent + 7924) [0x100001ef4]
                    42 ??? (in SecurityAgent + 8266) [0x10000204a]
                Kernel stack:
                Thread 87be000    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 89d67a8
                User stack:
                  36 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff80231a55]
                    36 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff802319da]
                Kernel stack:
                  36 workqueue_thread_yielded + 562 [0x4cb6ae]
                Binary Images:
                       0x100000000 -        0x100036ff7  com.apple.securityagent 5.1 (37245) <CEAC1960-55EF-57EE-3FD4-25384C3F6B37> /System/Library/CoreServices/SecurityAgent.app/Contents/MacOS/SecurityAgent
              Process:         securityd [25]
              Path:            /usr/sbin/securityd
              UID:             0
                Thread 86dd3d4    DispatchQueue 1
                User stack:
                  42 ??? (in securityd + 5608) [0x1000015e8]
                    42 ??? (in securityd + 7953) [0x100001f11]
                      42 ??? (in securityd + 27083) [0x1000069cb]
                        42 ??? (in securityd + 28091) [0x100006dbb]
                Kernel stack:
                Thread 8876000
                User stack:
                      42 ??? (in securityd + 33454) [0x1000082ae]
                        42 ??? (in securityd + 33606) [0x100008346]
                Kernel stack:
                Thread 88763d4
                User stack:
                Kernel stack:
                Thread 88d9000
                User stack:
                Kernel stack:
                Thread 88d93d4
                User stack:
                Kernel stack:
                Thread 88d97a8
                User stack:
                Kernel stack:
                Thread 88ef3d4
                User stack:
                Kernel stack:
                Thread 88ef7a8
                User stack:
                Kernel stack:
                Thread 88efb7c
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x1000e5fef  securityd ??? (???) <AF0F32E5-0D43-1B8B-9632-5A4B32E6A7F5> /usr/sbin/securityd
              Process:         spindump [265]
              Path:            /usr/sbin/spindump
              UID:             0
                Thread 98e83d4    DispatchQueue 1
                User stack:
                  42 ??? (in spindump + 3752) [0x100000ea8]
                    42 ??? (in spindump + 6427) [0x10000191b]
                          38 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff86daf7a2]
                            38 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff80217e3a]
                          4 __CFRunLoopRun + 3640 (in CoreFoundation) [0x7fff86daff38]
                            4 _dispatch_main_queue_callback_4CF + 37 (in libSystem.B.dylib) [0x7fff80265e4c]
                              4 _dispatch_queue_serial_drain_till_empty + 9 (in libSystem.B.dylib) [0x7fff80233127]
                                4 _dispatch_queue_drain + 251 (in libSystem.B.dylib) [0x7fff8023287a]
                                  4 _dispatch_call_block_and_release + 15 (in libSystem.B.dylib) [0x7fff80253ce8]
                                    4 ??? (in spindump + 10090) [0x10000276a]
                                      4 ??? (in spindump + 10652) [0x10000299c]
                                        4 AudioObjectGetPropertyDataSize + 143 (in CoreAudio) [0x7fff847bfafb]
                                          4 HALSystem::CheckOutInstance() + 364 (in CoreAudio) [0x7fff8479d662]
                                            4 HALSystem::InitializeDevices() + 9 (in CoreAudio) [0x7fff847a174d]
                                              2 HALPlugInManagement::Initialize() + 278 (in CoreAudio) [0x7fff847a1876]
                                                1 HALPlugInManagement::OpenPlugInsInDirectory(__CFString const*, char const*) + 135 (in CoreAudio) [0x7fff847a21cb]
                                                  1 readdir_r$INODE64 + 89 (in libSystem.B.dylib) [0x7fff8025e5a2]
                                                    1 __getdirentries64 + 10 (in libSystem.B.dylib) [0x7fff802222aa]
                                                1 HALPlugInManagement::OpenPlugInsInDirectory(__CFString const*, char const*) + 315 (in CoreAudio) [0x7fff847a227f]
                                                  1 HALCFPlugIn::HALCFPlugIn(__CFURL const*) + 19 (in CoreAudio) [0x7fff847a2443]
                                                    1 CFPlugInCreate + 25 (in CoreFoundation) [0x7fff86deafc9]
                                                      1 _CFBundleCreate + 697 (in CoreFoundation) [0x7fff86d6ff49]
                                                        1 CFBundleGetInfoDictionary + 74 (in CoreFoundation) [0x7fff86d778fa]
                                                          1 _CFBundleCopyInfoDictionaryInDirectoryWithVersion + 1371 (in CoreFoundation) [0x7fff86d77e5b]
                                                            1 CFURLCreateDataAndPropertiesFromResource + 185 (in CoreFoundation) [0x7fff86d7eff9]
                                                              1 open + 10 (in libSystem.B.dylib) [0x7fff802223fe]
                                              2 HALPlugInManagement::Initialize() + 362 (in CoreAudio) [0x7fff847a18ca]
                                                2 HALPlugInManagement::CreateHALPlugIn(HALCFPlugIn const*) + 1031 (in CoreAudio) [0x7fff847a2b1b]
                                                  2 HP_HardwarePlugIn_InitializeWithObjectID(AudioHardwarePlugInInterface**, unsigned int) + 66 (in CoreAudio) [0x7fff847a3964]
                                                    2 IOA_HWDeviceManager::Initialize() + 208 (in CoreAudio) [0x7fff847a6232]
                                                      2 IOA_HWDeviceManager::IOServiceMatchingHandler(IOA_HWDeviceManager*, unsigned int) + 333 (in CoreAudio) [0x7fff847a6389]
                                                        2 IOA_PlugIn::HWDevicesAdded(std::vector<IOA_HWDevice*, std::allocator<IOA_HWDevice*> > const&) + 252 (in CoreAudio) [0x7fff847a8316]
                                                          2 AudioObjectsPublishedAndDied + 277 (in CoreAudio) [0x7fff847ad53f]
                                                            2 HALSystem::ObjectsPublishedAndDied(unsigned int, unsigned int const*, unsigned int, unsigned int const*) + 535 (in CoreAudio) [0x7fff847af633]
                                                              2 HALDeviceList::DeviceCreated(HALDevice*) + 28 (in CoreAudio) [0x7fff847b1efe]
        2 HALDeviceList::AddDevice(HALDevice*) + 95 (in CoreAudio) [0x7fff847b1fef]
        2 HALDevice::IsHidden() const + 62 (in CoreAudio) [0x7fff847b22a8]
        2 HALDevice::HasProperty(AudioObjectPropertyAddress const&) const + 585 (in CoreAudio) [0x7fff847b251f]
        2 HALObject::HasProperty(AudioObjectPropertyAddress const&) const + 115 (in CoreAudio) [0x7fff847a43d1]
        2 HALPlugIn::ObjectHasProperty(HALObject const&, AudioObjectPropertyAddress const&) const + 39 (in CoreAudio) [0x7fff847b2565]
        2 HP_HardwarePlugIn_ObjectHasProperty(AudioHardwarePlugInInterface**, unsigned int, AudioObjectPropertyAddress const*) + 271 (in CoreAudio) [0x7fff847b26f1]
        2 IOA_SingleDevice::HasProperty(AudioObjectPropertyAddress const&) const + 661 (in CoreAudio) [0x7fff847b29c7]
        2 IOA_Device::HWPlugIn_DeviceHasProperty(AudioObjectPropertyAddress const&) const + 44 (in CoreAudio) [0x7fff847b2a68]
        2 IOA_SingleDevice::GetHWPlugInForProperty(AudioObjectPropertyAddress const&) const + 17 (in CoreAudio) [0x7fff847b2af5]
        2 IOA_SingleDevice::LoadDriverPlugIns() + 251 (in CoreAudio) [0x7fff847b2bff]
        2 IOA_HWPlugIn::IOA_HWPlugIn(__CFString const*, AudioDriverPlugInHostInfo const&) + 154 (in CoreAudio) [0x7fff847b2dc6]
        1 _CFBundleCreate + 333 (in CoreFoundation) [0x7fff86d6fddd]
        1 _CFBundleURLLooksLikeBundleVersion + 65 (in CoreFoundation) [0x7fff86d70e81]
        1 _CFBundleCopyDirectoryContentsAtPath + 1627 (in CoreFoundation) [0x7fff86d7180b]
        1 readdir$INODE64 + 67 (in libSystem.B.dylib) [0x7fff802221d0]
        1 read + 10 (in libSystem.B.dylib) [0x7fff80222426]
                Kernel stack:
                  38 ipc_mqueue_receive_continue + 0 [0x210aa3]
                  4 lo64_unix_scall + 77 [0x29e3fd]
                    3 unix_syscall64 + 617 [0x4ee947]
                      1 open_nocancel + 243 [0x2e94a8]
                        1 link + 1592 [0x2e8ffa]
                          1 vn_open_auth + 1121 [0x2ef89a]
                            1 VNOP_OPEN + 151 [0x2f9c51]
                              1 hfs_file_is_compressed + 3637 [0x43fa48]
                                1 hfs_file_is_compressed + 120 [0x43ec8b]
                                  1 decmpfs_file_is_compressed + 315 [0x30f854]
                                    1 decmpfs_hides_rsrc + 478 [0x30ed28]
                                      1 vn_getxattr + 330 [0x2f3927]
                                        1 VNOP_GETXATTR + 119 [0x2f677e]
                                          1 hfs_vnop_makenamedstream + 9843 [0x444070]
                                            1 BTSearchRecord + 684 [0x446967]
                                              1 SearchTree + 111 [0x44a08b]
                                                1 GetNode + 66 [0x448145]
                                                  1 netboot_mountroot + 10522 [0x411da3]
                                                    1 buf_biowait + 97 [0x2c7c92]
                                                      1 msleep + 157 [0x4882d6]
                                                        1 wakeup + 334 [0x487be3]
                                                          1 lck_mtx_sleep + 87 [0x2217b0]
                                                            1 thread_block + 33 [0x226fb5]
                                                              1 thread_block_reason + 331 [0x226f27]
        1 thread_dispatch + 1950 [0x226c88]
        1 machine_switch_context + 753 [0x2a5a37]
                      1 getdirentries64 + 112 [0x2e2cf9]
                        1 umask_extended + 984 [0x2e28c4]
                          1 VNOP_READDIR + 119 [0x2f6bc0]
                            1 hfs_owner_rights + 20681 [0x43ab72]
                              1 CompareCatalogKeys + 6740 [0x415ef0]
                                1 BTIterateRecords + 450 [0x445764]
                                  1 FindIteratorPosition + 135 [0x447d1f]
                      1 read_nocancel + 158 [0x496add]
                        1 write + 312 [0x49634d]
                          1 utf8_encodelen + 3711 [0x2eea08]
                            1 VNOP_READ + 157 [0x2f99b9]
                              1 hfs_vnop_read + 552 [0x4265ab]
                                1 cluster_read + 61 [0x2d244e]
                                  1 cluster_read_ext + 279 [0x2d1413]
                                    1 cluster_pageout + 3101 [0x2d0619]
                    1 unix_syscall64 + 932 [0x4eea82]
                      1 throttle_lowpri_io + 134 [0x30693b]
                        1 IOSleep + 25 [0x52b2e4]
                          1 delay_for_interval + 49 [0x21943d]
                Thread 88d9b7c    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread <multiple> DispatchQueue 17
                User stack:
                        42 _dispatch_queue_invoke + 57 (in libSystem.B.dylib) [0x7fff802326dc]
                          42 _dispatch_queue_drain + 261 (in libSystem.B.dylib) [0x7fff80232884]
                              42 _dispatch_source_invoke + 273 (in libSystem.B.dylib) [0x7fff8023339b]
                                42 ??? (in spindump + 16000) [0x100003e80]
                Kernel stack:
                      42 stack_snapshot + 85 [0x460d1e]
                        42 stack_snapshot2 + 147 [0x460c37]
                Thread 87beb7c
                User stack:
                      42 ??? (in spindump + 8819) [0x100002273]
                Kernel stack:
                Thread 87c4b7c
                User stack:
                Kernel stack:
                Thread 98463d4
                User stack:
                Kernel stack:
                Thread <multiple> DispatchQueue 14
                User stack:
                    6 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff80231bb8]
                      6 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x7fff80232286]
                        6 _dispatch_queue_invoke + 57 (in libSystem.B.dylib) [0x7fff802326dc]
                          6 _dispatch_queue_drain + 251 (in libSystem.B.dylib) [0x7fff8023287a]
                            6 _dispatch_call_block_and_release + 15 (in libSystem.B.dylib) [0x7fff80253ce8]
                              4 ??? (in spindump + 13025) [0x1000032e1]
                                4 ??? (in spindump + 13994) [0x1000036aa]
                                  4 _CFBundleCreateWithExecutableURLIfLooksLikeBundle + 187 (in CoreFoundation) [0x7fff86df182b]
                                    4 _CFBundleCreateIfLooksLikeBundle + 14 (in CoreFoundation) [0x7fff86df191e]
                                      2 _CFBundleCreate + 333 (in CoreFoundation) [0x7fff86d6fddd]
                                        2 _CFBundleURLLooksLikeBundleVersion + 65 (in CoreFoundation) [0x7fff86d70e81]
                                          1 stat64 + 10 (in libSystem.B.dylib) [0x7fff80221b12]
                                      2 _CFBundleCreate + 697 (in CoreFoundation) [0x7fff86d6ff49]
                                        2 CFBundleGetInfoDictionary + 74 (in CoreFoundation) [0x7fff86d778fa]
                                          2 _CFBundleCopyInfoDictionaryInDirectoryWithVersion + 1371 (in CoreFoundation) [0x7fff86d77e5b]
                                            2 CFURLCreateDataAndPropertiesFromResource + 185 (in CoreFoundation) [0x7fff86d7eff9]
                                              2 open + 10 (in libSystem.B.dylib) [0x7fff802223fe]
                              2 ??? (in spindump + 18912) [0x1000049e0]
                                2 ??? (in spindump + 14608) [0x100003910]
                                  2 dispatch_barrier_sync_f + 79 (in libSystem.B.dylib) [0x7fff8024cf4a]
                                    1 ??? (in spindump + 13025) [0x1000032e1]
                                      1 ??? (in spindump + 13994) [0x1000036aa]
                                        1 _CFBundleCreateWithExecutableURLIfLooksLikeBundle + 187 (in CoreFoundation) [0x7fff86df182b]
                                          1 _CFBundleCreateIfLooksLikeBundle + 14 (in CoreFoundation) [0x7fff86df191e]
                                    1 ??? (in spindump + 13056) [0x100003300]
                                      1 CFBundleGetValueForInfoDictionaryKey + 37 (in CoreFoundation) [0x7fff86d939a5]
                                        1 CFBundleGetLocalInfoDictionary + 85 (in CoreFoundation) [0x7fff86d93a45]
                                          1 CFBundleCopyResourceURL + 47 (in CoreFoundation) [0x7fff86d93bff]
                                            1 _CFBundleGetLanguageSearchList + 170 (in CoreFoundation) [0x7fff86d93daa]
                                              1 _CFBundleAddPreferredLprojNamesInDirectory + 1178 (in CoreFoundation) [0x7fff86d945da]
                                                  1 _CFBundleAddPreferredLprojNamesInDirectory + 404 (in CoreFoundation) [0x7fff86d942d4]
                                                    1 _CFBundleCopyUserLanguages + 665 (in CoreFoundation) [0x7fff86d94ab9]
                                                      1 CFPreferencesCopyAppValue + 43 (in CoreFoundation) [0x7fff86d94b1b]
                                                        1 __CFXPreferencesGetSearchListForBundleID + 674 (in CoreFoundation) [0x7fff86d94e32]
                                                          1 -[CFXPreferencesSearchListSource synchronize] + 94 (in CoreFoundation) [0x7fff86d9dfae]
                                                            1 -[CFXPreferencesPropertyListSource synchronize] + 103 (in CoreFoundation) [0x7fff86d9e047]
                Kernel stack:
                  5 lo64_unix_scall + 77 [0x29e3fd]
                      2 open_nocancel + 243 [0x2e94a8]
                        2 link + 1592 [0x2e8ffa]
                          2 vn_open_auth + 1121 [0x2ef89a]
                            2 VNOP_OPEN + 151 [0x2f9c51]
                              2 hfs_file_is_compressed + 3637 [0x43fa48]
                                2 hfs_file_is_compressed + 120 [0x43ec8b]
                                  2 decmpfs_file_is_compressed + 315 [0x30f854]
                                    2 decmpfs_hides_rsrc + 478 [0x30ed28]
                                      2 vn_getxattr + 330 [0x2f3927]
                                        2 VNOP_GETXATTR + 119 [0x2f677e]
                                          2 hfs_vnop_makenamedstream + 9843 [0x444070]
                                            2 BTSearchRecord + 684 [0x446967]
                                              2 SearchTree + 111 [0x44a08b]
                                                2 GetNode + 66 [0x448145]
                                                  2 netboot_mountroot + 10522 [0x411da3]
                                                    2 buf_biowait + 97 [0x2c7c92]
                      1 stat64 + 72 [0x2e5df6]
                        1 lstat_extended + 294 [0x2e5d5d]
                          1 pathconf + 275 [0x2e570f]
                            1 namei + 1577 [0x2d66f6]
                              1 VNOP_READLINK + 101 [0x2f6a58]
                                1 hfs_owner_rights + 19035 [0x43a504]
                    2 unix_syscall64 + 932 [0x4eea82]
                      2 throttle_lowpri_io + 134 [0x30693b]
                        2 IOSleep + 25 [0x52b2e4]
                          2 delay_for_interval + 49 [0x21943d]
                  1 thread_exception_return + 0 [0x29d655]
                Thread 98463d4    DispatchQueue 27
                User stack:
                  4 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff80231a55]
                    4 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff80231bb8]
                      4 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x7fff80232286]
                        4 _dispatch_queue_invoke + 57 (in libSystem.B.dylib) [0x7fff802326dc]
                              4 ??? (in spindump + 18912) [0x1000049e0]
                                4 ??? (in spindump + 14935) [0x100003a57]
                                  4 _dispatch_barrier_sync_f_slow + 142 (in libSystem.B.dylib) [0x7fff80253ec9]
                                    4 semaphore_wait_trap + 10 (in libSystem.B.dylib) [0x7fff80217e76]
                Kernel stack:
                  4 semaphore_wait_continue + 0 [0x22a0a5]
                Binary Images:
                       0x100000000 -        0x100010ff7  spindump ??? (???) <085A350B-140A-7032-9863-78646EABC2D7> /usr/sbin/spindump
                    0x7fff8479c000 -     0x7fff8481bfff  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <2633DFAC-F6A6-489D-8DF0-F12639CCD8C4> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
              Process:         spindump_symbolicator [266]
              Path:            /usr/libexec/spindump_symbolicator
              UID:             0
                Thread 97267a8    DispatchQueue 1
                User stack:
                  36 ??? (in spindump_symbolicator + 5772) [0x10000168c]
                    36 ??? (in spindump_symbolicator + 6159) [0x10000180f]
                      36 CFRunLoopRun + 70 (in CoreFoundation) [0x7fff86dae9b6]
                        36 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff86daec2f]
                          36 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff86daf7a2]
                            36 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff80217e3a]
                Kernel stack:
                  36 ipc_mqueue_receive_continue + 0 [0x210aa3]
                Thread 9928000    DispatchQueue 2
                User stack:
                    36 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff80231bb8]
                      36 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) [0x7fff80232286]
                        36 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff8023275c]
                          36 kevent + 10 (in libSystem.B.dylib) [0x7fff80230bba]
                Kernel stack:
                  36 kevent + 97 [0x471745]
                Thread 93937a8
                User stack:
                  3 thread_start + 13 (in libSystem.B.dylib) [0x7fff80250e41]
                    3 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff80250f8e]
                      3 cleaner_thread_main(void*) + 36 (in CoreSymbolication) [0x7fff863d60d5]
                        3 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff802529ee]
                Kernel stack:
                  3 semaphore_wait_continue + 0 [0x22a0a5]
                Binary Images:
                       0x100000000 -        0x100001fff  spindump_symbolicator ??? (???) <F714C29C-0C17-94A8-F8D0-6F88DD990C71> /usr/libexec/spindump_symbolicator
                    0x7fff863ca000 -     0x7fff8643cfef  com.apple.CoreSymbolication 2.0 (23) <06F8561E-4B36-7BF6-31BA-64091B3D8058> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
              Process:         syslogd [14]
              Path:            /usr/sbin/syslogd
              UID:             0
                Thread 81b2000    DispatchQueue 1
                User stack:
                  42 ??? (in syslogd + 2460) [0x10000099c]
                Kernel stack:
                Thread 85cb3d4
                User stack:
                      42 ??? (in syslogd + 35838) [0x100008bfe]
                        42 _vprocmgr_log_drain + 80 (in libSystem.B.dylib) [0x7fff8034265e]
                          42 vproc_mig_log_drain + 95 (in libSystem.B.dylib) [0x7fff8034304f]
                Kernel stack:
                Thread 85cb7a8
                User stack:
                      42 ??? (in syslogd + 46323) [0x10000b4f3]
                        42 ??? (in syslogd + 36771) [0x100008fa3]
                Kernel stack:
                Thread 85cbb7c
                User stack:
                      42 ??? (in syslogd + 45247) [0x10000b0bf]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100013fff  syslogd ??? (???) <72261A58-D9C8-558F-A6F5-BCC33F0EE52D> /usr/sbin/syslogd
              Process:         SystemUIServer [95]
              Path:            /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
              UID:             501
                Thread 93573d4    DispatchQueue 1
                User stack:
                  42 ??? (in SystemUIServer + 71088) [0x1000115b0]
                    42 ??? (in SystemUIServer + 72744) [0x100011c28]
                Kernel stack:
                Thread 878a3d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 98e8b7c
                User stack:
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100066fef  com.apple.systemuiserver 1.6 (298.5) <4AB10D03-2489-58F3-57CB-5F679A5F49CA> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
              Process:         usbmuxd [22]
              Path:            /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
              UID:             213
                Thread 86cc000    DispatchQueue 100
                User stack:
                  42 ??? (in usbmuxd + 3973) [0x1f85]
                    42 ??? (in usbmuxd + 4184) [0x2058]
                      42 ??? (in usbmuxd + 8842) [0x328a]
                        42 CFRunLoopRun + 84 (in CoreFoundation) [0x9233e7a4]
                          42 CFRunLoopRunSpecific + 452 (in CoreFoundation) [0x92338864]
                            42 __CFRunLoopRun + 2079 (in CoreFoundation) [0x9233977f]
                              42 mach_msg_trap + 10 (in libSystem.B.dylib) [0x949858da]
                Kernel stack:
                Thread 8876b7c    DispatchQueue 1634545000
                User stack:
                  42 start_wqthread + 30 (in libSystem.B.dylib) [0x949ab336]
                    42 _pthread_wqthread + 390 (in libSystem.B.dylib) [0x949ab4f1]
                      42 _dispatch_worker_thread2 + 234 (in libSystem.B.dylib) [0x949aba68]
                        42 _dispatch_queue_invoke + 163 (in libSystem.B.dylib) [0x949abcc3]
                          42 kevent + 10 (in libSystem.B.dylib) [0x949ac0ea]
                Kernel stack:
                Thread 886c000
                User stack:
                  42 thread_start + 34 (in libSystem.B.dylib) [0x949b2e42]
                    42 _pthread_start + 345 (in libSystem.B.dylib) [0x949b2fbd]
                      42 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x949a4856]
                Kernel stack:
                Binary Images:
                    0x1000 -     0xafff  usbmuxd ??? (???) <4344CCF1-B5DF-7098-E465-61FDCFE9DF68> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
                0x922fd000 - 0x92474fef  com.apple.CoreFoundation 6.6.1 (550.13) <AE9FC6F7-F0B2-DE58-759E-7DB89C021A46> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                0x94985000 - 0x94b29feb  libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
              Process:         UserEventAgent [113]
              Path:            /usr/libexec/UserEventAgent
              UID:             501
                Thread 93933d4    DispatchQueue 1
                User stack:
                  42 ??? (in UserEventAgent + 3740) [0x100000e9c]
                    42 ??? (in UserEventAgent + 6152) [0x100001808]
                Kernel stack:
                Thread 9877000    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 98773d4
                User stack:
                      42 __NSThread__main__ + 1429 (in Foundation) [0x7fff84e18e99]
                        42 RegisterAppTracker + 8174 (in ACRRDaemon) [0x1000455e5]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100001fff  UserEventAgent ??? (???) <D7E00D4C-D72A-B658-5BA2-3E0B9A6FA3EA> /usr/libexec/UserEventAgent
                       0x100042000 -        0x100047fff  com.apple.CrashReporter.ACRRDaemonPlugin 10.6.2 (239) <91385300-943E-6AE9-D2A6-9BED0834A776> /System/Library/UserEventPlugins/ACRRDaemon.plugin/Contents/MacOS/ACRRDaemon
              Process:         WindowServer [59]
              Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framewor k/Resources/WindowServer
              UID:             88
                Thread 87ad7a8    DispatchQueue 1
                User stack:
                  42 start + 52 (in WindowServer) [0x100000f18]
                    42 main + 9 (in WindowServer) [0x100000f29]
                      42 CGXGetRootAdminCredentials + 0 (in CoreGraphics) [0x7fff82916ae6]
                        42 CGXServerLoop + 139 (in CoreGraphics) [0x7fff8294b7c6]
                          42 CGXRunOneServicesPass + 357 (in CoreGraphics) [0x7fff82942956]
                            40 CGXRunOneServerPass + 262 (in CoreGraphics) [0x7fff82945746]
                            2 CGXRunOneServerPass + 208 (in CoreGraphics) [0x7fff82945710]
                Kernel stack:
                Thread 8fae3d4    DispatchQueue 2
                User stack:
                Kernel stack:
                Thread 865a000
                User stack:
                      42 thread_fun + 34 (in QuartzCore) [0x7fff82fa3c52]
                        42 CA::Render::Server::server_thread(void*) + 177 (in QuartzCore) [0x7fff82fa3d12]
                Kernel stack:
                Thread 886c3d4
                User stack:
                      42 eventThread + 441 (in CoreGraphics) [0x7fff82928441]
                Kernel stack:
                Binary Images:
                       0x100000000 -        0x100000fff  WindowServer ??? (???) <8EE67EB5-FD3B-C594-DACD-8DD8F83621C7> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framewor k/Resources/WindowServer
                    0x7fff8285c000 -     0x7fff82f50537  com.apple.CoreGraphics 1.536.12 (???) <0DCA088B-0C6B-146F-0341-9E0212B5CA50> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                    0x7fff82f51000 -     0x7fff832e9fff  com.apple.QuartzCore 1.6.1 (227.8) <E296B174-F7CB-F021-D103-091CCB33BBEB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
              Process:         kernel_task [0]
              Path:            kernel_task
              UID:             0
              Version:         Darwin Kernel Version 10.2.0: Tue Nov  3 10:37:10 PST 2009; root:xnu-1486.2.11~1/RELEASE_I386
                Thread 0
                Thread 863a80
                Kernel stack:
                  42 vm_pageout_continue + 0 [0x2769a0]
                Thread 7edd000
                Kernel stack:
                  42 thread_stack_enqueue + 90 [0x22e2bb]
                Thread 7edd3d4
                Kernel stack:
                  42 thread_daemon_init + 214 [0x22e028]
                Thread 7edd7a8
                Kernel stack:
                  42 assert_wait_deadline + 271 [0x227980]
                Thread 7eddb7c
                Kernel stack:
                  42 idle_thread + 0 [0x227e4a]
                Thread 7ede000
                Kernel stack:
                  42 IOWorkLoop::threadMain() + 0 [0x548626]
                Thread 7ede3d4
                Kernel stack:
                Thread 7ede7a8
                Kernel stack:
                Thread 7edeb7c
                Kernel stack:
                  42 thread_call_initialize + 334 [0x22f76c]
                Thread 804c000
                Kernel stack:
                Thread 804cb7c
                Kernel stack:
                Thread 8052000
                Kernel stack:
                Thread 80523d4
                Kernel stack:
                Thread 80527a8
                Kernel stack:
                  42 call_continuation + 28 [0x29d68c]
                    42 com.apple.driver.AppleIntelCPUPowerManagement 96.0.0 + 20524 [0x11a502c]
                Thread 8053000
                Kernel stack:
                Thread 80533d4
                Kernel stack:
                    42 buf_strategy + 1042 [0x2c93ec]
                Thread 80537a8
                Kernel stack:
                  40 thread_call_initialize + 620 [0x22f88a]
                    2 thread_call_initialize + 853 [0x22f973]
                      2 IOTimerEventSource::timeoutAndRelease(void*, void*) + 144 [0x54c1ae]
                        2 com.apple.driver.AppleHDA 1.7.9a4 + 14411 [0x10b484b]
                          2 IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 271 [0x549661]
                            2 com.apple.driver.AppleHDA 1.7.9a4 + 26702 [0x10b784e]
                              2 com.apple.driver.AppleHDA 1.7.9a4 + 26258 [0x10b7692]
                                2 com.apple.driver.AppleHDA 1.7.9a4 + 165124 [0x10d9504]
                Thread 8053b7c
                Kernel stack:
                Thread 807a000
                Kernel stack:
                Thread 807ab7c
                Kernel stack:
                  42 thread_call_initialize + 620 [0x22f88a]
                Thread 807d3d4
                Kernel stack:
                Thread 807d7a8
                Kernel stack:
                  42 aio_return + 295 [0x4649ea]
                Thread 807f7a8
                Kernel stack:
                  42 m_freem + 15868 [0x4a7b6b]
                Thread 807fb7c
                Kernel stack:
                    42 audit_worker_init + 956 [0x460332]
                      42 _audit_cv_wait + 50 [0x4514e6]
                Thread 8080000
                Kernel stack:
                Thread 80803d4
                Kernel stack:
                  42 com.apple.nke.applicationfirewall 2.1.11 + 23895 [0x1400d57]
                Thread 80807a8
                Kernel stack:
                Thread 8080b7c
                Kernel stack:
                Thread 8085000
                Kernel stack:
                Thread 80853d4
                Kernel stack:
                Thread 8085b7c
                Kernel stack:
                Thread 809b000
                Kernel stack:
                  42 vm_pageout_internal_start + 945 [0x275293]
                Thread 809b3d4
                Kernel stack:
                  42 memory_object_recover_named + 18260 [0x26f55a]
                Thread 809bb7c
                Kernel stack:
                Thread 809e000
                Kernel stack:
                Thread 80a3000
                Kernel stack:
                Thread 80a33d4
                Kernel stack:
                Thread 80a37a8
                Kernel stack:
                Thread 80a3b7c
                Kernel stack:
                  42 vm_pageout_internal_start + 80 [0x274f32]
                Thread 816c000
                Kernel stack:
                    42 ux_handler_init + 475 [0x4d19f2]
                      42 mach_msg_receive + 168 [0x216ca5]
                        42 ipc_mqueue_receive + 101 [0x21191c]
                Thread 816c3d4
                Kernel stack:
                Thread 816c7a8
                Kernel stack:
                  42 ifnet_detach + 582 [0x31816e]
                Thread 816cb7c
                Kernel stack:
                    42 ifnet_detach_protocol + 1591 [0x3189cc]
                Thread 865b3d4
                Kernel stack:
                Thread 865b7a8
                Kernel stack:
                Thread 86ddb7c
                Kernel stack:
                    42 com.apple.filesystems.autofs 2.1.0 + 24145 [0x1374e51]
                        42 wakeup + 286 [0x487bb3]
                          42 lck_mtx_sleep_deadline + 104 [0x2211a8]
                Thread 871e3d4
                Kernel stack:
                Thread 87c43d4
                Kernel stack:
                    42 com.apple.driver.AppleIntelCPUPowerManagement 96.0.0 + 19503 [0x11a4c2f]
                Thread 87c57a8
                Kernel stack:
                Thread 89097a8
                Kernel stack:
                Thread 89df000
                Kernel stack:
                Thread 8a7a000
                Kernel stack:
                Thread 8fabb7c
                Kernel stack:
                Thread 8fac000
                Kernel stack:
                Thread 8fad000
                Kernel stack:
