Revision: 13389
Revision: 13389
Author: gruehle@adobe.com
Date: 2010-01-08 14:39:49 -0800 (Fri, 08 Jan 2010)
Log Message:
Deprecate (mostly) creationPolicy="queued". This feature hasn't worked correctly since Flex 1.5.
The ContainerCreationPolicy.QUEUED property could not be deprecated due to a bug, but the Container.creationIndex property is deprecated, and the "queued" option is removed from the inspectable metadata enumeration.
QE notes: None
Doc notes: Documentation that mentions creationPolicy="queued" should be removed
Bugs: SDK-24479
Reviewer: Corey
Tests run: Checkin
Is noteworthy for integration: No
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24479
Modified Paths:
flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/core/Container.as
flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/core/ContainerCreationPolicy.as
