[svn:fx-4.0.0] 13391: Updating OSMF for the ASDoc updates and taking a new SWC and RSL.
rfrishbe Jan 8, 2010 4:12 PMRevision: 13391
Revision: 13391
Author: rfrishbe@adobe.com
Date: 2010-01-08 16:12:48 -0800 (Fri, 08 Jan 2010)
Log Message:
QE notes: -
Doc notes: -
Bugs: -
Reviewer: Deepa
Tests run: checkintests
Is noteworthy for integration: no
Modified Paths:
flex/sdk/branches/4.0.0/frameworks/air-config.xml
flex/sdk/branches/4.0.0/frameworks/flex-config.xml
flex/sdk/branches/4.0.0/frameworks/libs/osmf.swc
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/audio/AudioElement.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/audio/AudioSeekableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/audio/SoundAdapter.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/audio/SoundDownloadableTrai t.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/audio/SoundLoadedContext.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/audio/SoundLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeAudibl eTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeBuffer ableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeMetada ta.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositePausab leTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositePlayab leTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeSeekab leTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeSpatia lTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeTempor alTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/CompositeViewab leTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/ParallelSeekabl eTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/ParallelSpatial Trait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/ParallelSwitcha bleTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/ParallelViewabl eTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/SerialSeekableT rait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/SerialSpatialTr ait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/SerialSwitchabl eTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/composition/SerialViewableT rait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/content/ContentElement.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/content/ContentLoadedContex t.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/content/ContentLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/display/MediaElementSprite. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/display/MediaPlayerSprite.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/display/ScalableSprite.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/display/ScaleMode.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/display/ScaleModeUtils.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/drm/DRMServices.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/AudioEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/BufferEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/ContentProtectionEve nt.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/DimensionEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/FacetValueChangeEven t.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/FacetValueEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/GatewayChangeEvent.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/LoadEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/MediaError.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/MediaErrorEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/MediaPlayerCapabilit yChangeEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/MediaPlayerStateChan geEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/MetadataEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/NetConnectionFactory Event.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/NetNegotiatorEvent.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/PausedChangeEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/PlayingChangeEvent.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/PluginLoadEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/SeekEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/SwitchEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/TimeEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/events/ViewEvent.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/gateways/HTMLGateway.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/gateways/RegionGateway.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/image/ImageElement.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/image/ImageLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/AbsoluteLayoutFacet. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/AnchorLayoutFacet.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/DefaultLayoutRendere r.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/ILayoutContext.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/ILayoutRenderer.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/ILayoutTarget.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/LayoutAttributesFace t.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/LayoutContextSprite. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/LayoutRendererBase.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/LayoutRendererFacet. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/LayoutUtils.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/MediaElementLayoutTa rget.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/PaddingLayoutFacet.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/RegistrationPoint.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/layout/RelativeLayoutFacet. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/logging/ILogger.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/logging/ILoggerFactory.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/logging/Log.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/logging/TraceLogger.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/logging/TraceLoggerFactory. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/media/IContainerGateway.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/media/MediaElement.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/media/MediaPlayer.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/media/MediaPlayerState.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/media/URLResource.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/IFacet.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/IIdentifier.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/KeyValueFacet.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/MediaType.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/Metadata.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/MetadataNamespaces .as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/MetadataUtils.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/MetadataWatcher.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/ObjectFacet.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/ObjectIdentifier.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/StringIdentifier.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/TemporalFacet.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/TemporalFacetEvent .as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/metadata/TemporalIdentifier .as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetClient.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetConnectionCodes.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetConnectionFactory.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetLoadedContext.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetNegotiator.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamAudibleTrait.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamBufferableTrai t.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamCodes.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamContentProtect ableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamDownloadableTr ait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamPausableTrait. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamPlayableTrait. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamSeekableTrait. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/NetStreamTemporalTrait. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/StreamType.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Droppe dFramesRule.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Dynami cNetStream.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Dynami cStreamingItem.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Dynami cStreamingNetLoadedContext.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Dynami cStreamingNetLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Dynami cStreamingResource.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/INetSt reamMetrics.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/ISwitc hingRule.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Insuff icientBandwidthRule.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Insuff icientBufferRule.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Metric sProvider.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/NetStr eamSwitchableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Suffic ientBandwidthRule.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Switch ingDetail.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Switch ingDetailCodes.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/Switch ingRuleBase.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/DynamicPluginLoader. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/IPluginInfo.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/PluginClassResource. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/PluginElement.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/PluginLoadedContext. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/PluginLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/plugin/StaticPluginLoader.a s
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/swf/SWFElement.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/swf/SWFLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/tracking/Beacon.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/AudibleTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/BufferableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/ContentProtectableTr ait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/DownloadableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IAudible.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IBufferable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IContentProtectable. as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IDisposable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IDownloadable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IPausable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IPlayable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/ISeekable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/ISpatial.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/ISwitchable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/ITemporal.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/IViewable.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/LoadState.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/LoadableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/MediaTraitType.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/PausableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/PlayableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/SeekableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/SpatialTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/SwitchableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/TemporalTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/traits/ViewableTrait.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/utils/BinarySearch.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/utils/FMSHost.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/utils/FMSURL.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/utils/HTTPLoader.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/utils/URL.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/video/CuePoint.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/video/CuePointType.as
flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/video/VideoElement.as
Added Paths:
flex/sdk/branches/4.0.0/frameworks/rsls/osmf_flex.4.0.0.13386.swf
Removed Paths:
flex/sdk/branches/4.0.0/frameworks/rsls/osmf_flex.4.0.0.13104.swf
