1 Reply Latest reply on Jan 9, 2010 3:30 AM by Muppet Mark-QAl63s
    How to Export PDF to Text File?
    Oviya...
      Hi pals,
      Am doing Applescript to convert PDF to Text. Is there any possibilities to do in Applescript or Javascript (by calling Javascript syntax using doScript in applescript). I need either .txt file or .doc file.Thanks in advance.
      by,
      Oviya
        • 1. Re: How to Export PDF to Text File?
          Muppet Mark-QAl63s Level 4
          Use save document command with using conversion… Here is an example for plain text.
          property Default_Location : (path to desktop as Unicode text) as alias
          set Input_Folder to choose folder default location Default_Location with prompt "Select a folder of PDFs" without invisibles
          tell application "Finder"
          set File_List to (files of Input_Folder whose name extension is "pdf")
          repeat with This_File in File_List
          set The_File to This_File as alias
          tell application "Adobe Acrobat 7.0 Professional"
          activate
          open The_File
          set Doc_Name to name of document 1
          set Base_Name to my getBaseName(Doc_Name)
          set New_File_Path to (Default_Location as string) & Base_Name & ".txt"
          save front document to file New_File_Path using conversion "com.adobe.acrobat.plain-text"
          close front document
          end tell
          end repeat
          end tell
          on getBaseName(fName)
          set baseName to fName
          repeat with idx from 1 to (length of fName)
          if (item idx of fName = ".") then
          set baseName to (items 1 thru (idx - 1) of fName) as string
          exit repeat
          end if
          end repeat
          return baseName
          end getBaseName
          Other text conversions are "com.adobe.acrobat.rtf" & "com.adobe.acrobat.accesstext"
