0 Replies Latest reply on Jan 8, 2010 5:50 PM by deepa subramaniam (adobe)
    [svn:fx-4.0.0] 13392: We do not allow display object sharing in a Group if the Group has layering or if blendMode is not normal .
      Revision: 13392
      Revision: 13392
      Author:   dsubrama@adobe.com
      Date:     2010-01-08 17:50:20 -0800 (Fri, 08 Jan 2010)
      Log Message:
      We do not allow display object sharing in a Group if the Group has layering or if blendMode is not normal. blendMode is not normal if its been explicitly set to a particular value or if its auto and there is a non-integer alpha at play.
      QE notes: There will be mustella failures, especially anything using ScrollBar or Button - they will not be noticeable to the human eye, but mustella will catch it. Steve S and Joann have cycloned the change and excluded most of what will fail (and wil re-gen bitmaps on Monday), however I'm sure some stuff hasn't been excluded that should so be on the lookout for failing bitmaps.
      Doc notes: None
      Bugs: SDK-24667
      Reviewer: Corey
      Tests run: Cyclone to QA
      Is noteworthy for integration: No
      Merge to trunk: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24667
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/Group.as
