0 Replies Latest reply on Jan 8, 2010 9:23 PM by artificiallyreal
    Problem: XML object in ArrayCollection All Identical
    artificiallyreal
      Good day,
      I'm new to the forum and apologise if this discussion is in the wrong location. I'm very stuck with a particular problem. I am generating a series of XML objects via a private function within a component class and adding these to a arrayCollection. Each time an XML object is added to the arrayCollection all other XML objects in the arrayCollection become identical to the last object added.
      private function setTypes():void
                     setTypesArr.removeAll();
                     for(var i:Number=0; i<_attArray.length; i++)
                          var passXML:XML = passAttTypes(i+1);
                          setTypesArr[i] = passXML;
      private function passAttTypes(curAtt:Number):XML
                     var attList:XMLList = _attTypesArr.children();
                     for each(var att:AttributeVO in _attArray)
                          if(att.attNumber != curAtt)
                               for each(var type:XML in attList)
                                    var attType:Number = Number(type.@number.toString());
                                    if(att.attType == attType)
                                         type.@enabled = false;
                          }else{
                               for each(var t:XML in attList)
                                    var AttType:Number = Number(t.@number.toString());
                                    if(att.attType == AttType)
                                         t.@enabled = true;
      Any suggestions more than welcome.
      regards,
      Rob
