17 Replies Latest reply: Jan 18, 2010 6:22 PM by Bill Gehrke RSS
    PPBM4 Benchmark : Discussing my results...
    kohns Community Member
      http://ppbm4.com/Benchmark.html
      My stats are under kohns_01.
      Why come does it come that HB-i7core-975 , Solo7   Graham and my 'Export AVI (Sec.)' result is so poor.
      Any idea on how that comes (what is importand for exporting AVI) and how to improve it?
      It is a fresh install and I am still tweaking it.  I already:
      • removed/disabled a lot of services
      • disabled firewall
      • turned of disk indexing
      • changed windows to "Best Performance"
      • turned of Themes
        • 1. Re: PPBM4 Benchmark : Discussing my results...
          Bill Gehrke Community Member
          Exporting AVI is a disk intensive benchmark.  Run HDtach (a free utility) on both your OS disk and your RAID array and report the burst transfer rate, the average read transfer rate and CPU utilization.
          • 2. Re: PPBM4 Benchmark : Discussing my results...
            Thanks for the feedback.
            My system crashed... and getting : unable to find NTLDR ... so I will do those tests after I recovered.
            Soon I hope ...
            • 3. Re: PPBM4 Benchmark : Discussing my results...
              Harm Millaard CommunityMVP
              Very observative that you noticed Graham's, Horatio's and your own AVI scores to be less than expected with your disk setups. You all have good disk setups, and one would expect better results. HDTach, as Bill mentioned, can be indicative of potential bottlenecks that keep you from top-notch performance. In addition it may be wise to inspect Process Explorer results to see what processes are running in the background that prevent better results. But first get your system up-and-running. Good luck.
              • 4. Re: PPBM4 Benchmark : Discussing my results...
                I am almost there... finished the reinstall of windows/windows-updates/drivers and took a new image.  I am now tweaking it again before I start installing Adobe and do those tests again...
                It should be a little faster now because I now also replaced my 160GB WD 7200RPM with a 150GB WD Velociraptor 10000RPM.  Can't wait to run my first benchmark again...
                • 5. Re: PPBM4 Benchmark : Discussing my results...
                  Ok my PC is "ready" for the first test... but it is not looking much better even with the new faster OS disk ... on the contrary ...
                  old run prior to crashnew run
                    Computer ManufacturerASUSAsus
                     Computer ModelP6T SEP6T SE
                    secs Total Benchmark Time4747.2
                    secs AVI  Encoding Time4.54.4
                    secs MPEG Elapsed Time29.529.8
                    secs Rendering Time1313
                      CPU ManufacturerINTELIntel
                      CPU ModelCore i7 960 45nm 3.20Core i7 960 45nm 3.20
                      GHz CPU speed3.23.2
                      Number of CPU chips22
                      Total Number of Cores44
                      GB RAM1212
                      APP Version PPBM4 DV4.2.14.2.1
                      OSVersionWin 7 Pro 64 bitWin 7 Pro 64 bit
                      OS Disk InterfaceSATASATA
                      GB OS Disk Capacity160150
                      OS Disk Speed720010000
                      Project Disk InterfaceSATASATA
                      GB Project Disk Capacity1000x6 R01000x6 R0
                      Project Disk Speed72007200
                      Preview Disk InterfaceSame as Project DiskSame as Project Disk
                      GB Preview Disk CapacitySame as Project DiskSame as Project Disk
                      Preview Disk SpeedSame as Project DiskSame as Project Disk
                      Output Disk InterfaceSame qs Project DiskSame as Project Disk
                      GB Output Disk CapacitySame as Project DiskSame as Project Disk
                      Output Disk SpeedSame as Project DiskSame as Project Disk
                      Graphics BoardASUS EAH5770Asus EAH5770
                      CommentWindows Pagefile on seperate disk 320GB x 2 Raid0Windows Pagefile on seperate disk 320GB x 2 Raid0
                  Project Disk on Areca   1220 Cntrl Project Disk on Areca 1220 Cntrl
                  Internet controller disabled and firewall as well (no virusscanner installed or running)
                  The processes running (tasklist /V) seconds before I hit "Start Queue" on AME...
                  ImagenameProces-iSession nameSession nr.Mem UsageStatusUsernameWindowname
                  System Idle Process0Services024 kBUnknownNT AUTHORITY\SYSTEMn.v.t.
                  System4Services01.988 kBUnknownn.v.t.n.v.t.
                  smss.exe364Services01.308 kBUnknownn.v.t.n.v.t.
                  csrss.exe456Services04.236 kBUnknownn.v.t.n.v.t.
                  wininit.exe508Services04.700 kBUnknownn.v.t.n.v.t.
                  csrss.exe532Console118.220 kBRunningn.v.t.n.v.t.
                  services.exe564Services08.356 kBUnknownn.v.t.n.v.t.
                  lsass.exe588Services010.408 kBUnknownn.v.t.n.v.t.
                  lsm.exe600Services04.480 kBUnknownn.v.t.n.v.t.
                  svchost.exe692Services09.920 kBUnknownn.v.t.n.v.t.
                  winlogon.exe728Console16.192 kBUnknownn.v.t.n.v.t.
                  svchost.exe816Services07.968 kBUnknownn.v.t.n.v.t.
                  svchost.exe920Services017.300 kBUnknownn.v.t.n.v.t.
                  svchost.exe952Services0118.720 kBUnknownn.v.t.n.v.t.
                  svchost.exe980Services029.796 kBUnknownn.v.t.n.v.t.
                  audiodg.exe384Services015.852 kBUnknownn.v.t.n.v.t.
                  svchost.exe412Services07.560 kBUnknownn.v.t.n.v.t.
                  svchost.exe1092Services012.464 kBUnknownn.v.t.n.v.t.
                  spoolsv.exe1396Services011.432 kBUnknownn.v.t.n.v.t.
                  svchost.exe1432Services011.588 kBUnknownn.v.t.n.v.t.
                  taskhost.exe1844Console16.688 kBRunningVideo\Home UserMCI command handling window
                  explorer.exe1960Console145.328 kBRunningVideo\Home Usern.v.t.
                  cmd.exe1324Console13.060 kBRunningVideo\Home UserC:\Windows\system32\cmd.exe - tasklist  /V
                  conhost.exe892Console14.592 kBRunningVideo\Home UserOleMainThreadWndName
                  sppsvc.exe2804Services05.472 kBUnknownn.v.t.n.v.t.
                  svchost.exe2880Services029.048 kBUnknownn.v.t.n.v.t.
                  Adobe Media Encoder.exe2272Console1119.116 kBRunningVideo\Home UserAdobe Media Encoder
                  PhotoshopServer.exe2240Console124.184 kBRunningVideo\Home UserFont Capture
                  conhost.exe1540Console13.160 kBUnknownVideo\Home Usern.v.t.
                  processcoordinationserver744Console17.100 kBRunningVideo\Home Usern.v.t.
                  FNPLicensingService.exe1392Services04.364 kBUnknownn.v.t.n.v.t.
                  WmiPrvSE.exe2088Services06.584 kBUnknownn.v.t.n.v.t.
                  dynamiclinkmanager.exe520Console17.168 kBRunningVideo\Home UserOleMainThreadWndName
                  PProHeadless.exe2900Console186.444 kBRunningVideo\Home UserGDI+ Window
                  ImporterProcessServer.exe2596Console199.024 kBRunningVideo\Home UserActiveMovie Window
                  PhotoshopServer.exe2516Console126.020 kBRunningVideo\Home UserFont Capture
                  conhost.exe2508Console13.128 kBUnknownVideo\Home Usern.v.t.
                  tasklist.exe1784Console16.400 kBUnknownVideo\Home Usern.v.t.
                  WmiPrvSE.exe2316Services06.648 kBUnknownn.v.t.n.v.t.
                  HDTach results of my 3 disks few minutes after the benchmark ran
                  And below is a list of how I configured services to start/disable/...
                  Next to that I also disabled indexing on all drives and defragment all drives seconds before I ran the benchmark
                  Startup TypeStatusName
                  AutomaticStartedWorkstation
                  AutomaticStartedWindows Modules Installer
                  AutomaticStartedWindows Management Instrumentation
                  AutomaticStartedWindows Firewall
                  AutomaticStartedWindows Event Log
                  AutomaticStartedWindows Driver Foundation - User-mode Driver Framework
                  AutomaticStartedWindows Audio Endpoint Builder
                  AutomaticStartedUser Profile Service
                  AutomaticStartedTrueVector Internet Monitor
                  AutomaticStartedTCP/IP NetBIOS Helper
                  AutomaticStartedTask Scheduler
                  AutomaticStartedSystem Event Notification Service
                  AutomaticStartedSuperfetch
                  AutomaticStartedShell Hardware Detection
                  AutomaticStartedServer
                  AutomaticStartedSecurity Accounts Manager
                  AutomaticStartedRPC Endpoint Mapper
                  AutomaticStartedRemote Procedure Call (RPC)
                  AutomaticStartedProgram Compatibility Assistant Service
                  AutomaticStartedPrint Spooler
                  AutomaticStartedPower
                  AutomaticStartedPlug and Play
                  AutomaticStartedNetwork Store Interface Service
                  AutomaticStartedNetwork Location Awareness
                  AutomaticStartedIKE and AuthIP IPsec Keying Modules
                  AutomaticStartedGroup Policy Client
                  AutomaticStartedDNS Client
                  AutomaticStartedDHCP-client
                  AutomaticStartedDCOM Server Process Launcher
                  AutomaticStartedCryptographic Services
                  AutomaticStartedCOM+ Event System
                  AutomaticStartedBase Filtering Engine
                  AutomaticStartedWindows Update
                  AutomaticStartedWindows Defender
                  AutomaticStartedSoftware Protection
                  AutomaticStartedSecurity Center
                  ManualStartedUPnP Device Host
                  ManualStartedSSDP Discovery
                  ManualStartedSPP Notification Service
                  ManualStartedNetwork List Service
                  ManualStartedNetwork Connections
                  ManualStartedIPsec Policy Agent
                  ManualStartedBackground Intelligent Transfer Service
                  ManualStartedApplication Information
                  AutomaticMultimedia Class Scheduler
                  ManualWMI Performance Adapter
                  ManualWired AutoConfig
                  ManualWindows Time
                  ManualWindows Presentation Foundation Font Cache 3.0.0.0
                  ManualWindows Installer
                  ManualWindows Image Acquisition (WIA)
                  ManualWindows Font Cache Service
                  ManualWindows Event Collector
                  ManualWindows Connect Now - Config Registrar
                  ManualWindows Color System
                  ManualWindows CardSpace
                  ManualWindows Biometric Service
                  ManualWebClient
                  ManualVolume Shadow Copy
                  ManualVirtual Disk
                  ManualThread Ordering Server
                  ManualTelephony
                  ManualSecure Socket Tunneling Protocol Service
                  ManualSecondary Logon
                  ManualRemote Access Connection Manager
                  ManualRemote Access Auto Connection Manager
                  ManualQuality Windows Audio Video Experience
                  ManualProtected Storage
                  ManualPnP-X IP Bus Enumerator
                  ManualPerformance Logs & Alerts
                  ManualPerformance Counter DLL Host
                  ManualMicrosoft iSCSI Initiator Service
                  ManualMicrosoft .NET Framework NGEN v2.0.50727_X86
                  ManualMicrosoft .NET Framework NGEN v2.0.50727_X64
                  ManualKtmRm for Distributed Transaction Coordinator
                  ManualInteractive Services Detection
                  ManualHomeGroup Provider
                  ManualHomeGroup Listener
                  ManualExtensible Authentication Protocol
                  ManualDistributed Transaction Coordinator
                  ManualDisk Defragmenter
                  ManualCredential Manager
                  ManualCOM+ System Application
                  ManualCNG Key Isolation
                  ManualBitLocker Drive Encryption Service
                  ManualApplication Management
                  ManualApplication Identity
                  ManualApplication Experience
                  ManualActiveX Installer (AxInstSV)
                  DisabledWWAN AutoConfig
                  DisabledWLAN AutoConfig
                  DisabledWinHTTP Web Proxy Auto-Discovery Service
                  DisabledWindows Search
                  DisabledWindows Remote Management (WS-Management)
                  DisabledWindows Media Player Network Sharing Service
                  DisabledWindows Media Center Scheduler Service
                  DisabledWindows Media Center Receiver Service
                  DisabledWindows Error Reporting Service
                  DisabledWindows Backup
                  DisabledTPM Base Services
                  DisabledThemes
                  DisabledTablet PC Input Service
                  DisabledStorage Service
                  DisabledSNMP Trap
                  DisabledSmart Card Removal Policy
                  DisabledSmart Card
                  DisabledRouting and Remote Access
                  DisabledRemote Registry
                  DisabledRemote Procedure Call (RPC) Locator
                  DisabledRemote Desktop Services UserMode Port Redirector
                  DisabledRemote Desktop Configuration
                  DisabledProblem Reports and Solutions Control Panel Support
                  DisabledPortable Device Enumerator Service
                  DisabledPNRP Machine Name Publication Service
                  DisabledPeer Networking Identity Manager
                  DisabledPeer Networking Grouping
                  DisabledPeer Name Resolution Protocol
                  DisabledParental Controls
                  DisabledOffline Files
                  DisabledNetwork Access Protection Agent
                  DisabledNetlogon
                  DisabledNet.Tcp Port Sharing Service
                  DisabledMicrosoft Software Shadow Copy Provider
                  DisabledMedia Center Extender Service
                  DisabledLink-Layer Topology Discovery Mapper
                  DisabledIP Helper
                  DisabledInternet Connection Sharing (ICS)
                  DisabledIntel(R) Matrix Storage Event Monitor
                  DisabledHuman Interface Device Access
                  DisabledHealth Key and Certificate Management
                  DisabledFunction Discovery Resource Publication
                  DisabledFunction Discovery Provider Host
                  DisabledFax
                  DisabledEncrypting File System (EFS)
                  DisabledDistributed Link Tracking Client
                  DisabledDiagnostic System Host
                  DisabledDiagnostic Service Host
                  DisabledDiagnostic Policy Service
                  DisabledDesktop Window Manager Session Manager
                  DisabledComputer Browser
                  DisabledCertificate Propagation
                  DisabledBranchCache
                  DisabledBluetooth Support Service
                  DisabledBlock Level Backup Engine Service
                  DisabledApplication Layer Gateway Service
                  DisabledAMD External Events Utility
                  DisabledAdaptive Brightness
                  • 6. Re: PPBM4 Benchmark : Discussing my results...
                    While waiting on your thoughts on my above results I wanted to do some more investigation myself  by comparing my disk setup and HDTach results with Harm his results.
                    I found this picture from you Harm in my other thread and wanted to compare them with my results (see above) and think you made some typo errors ...
                    First surprising thing is that your 2x1TB raid0 has a burst speed 4x higher then your 12x1TB raid30 !?!?
                    So I think those 2 numbers should be switched.
                    And if they are switched I also think that a burst speed of 1158 for your 2x1TB raid0 is impossible.
                    If I compare your numbers with my numbers we get this graphic:
                    Harm his   Disk SpecsMy Disk Specs
                    CWindows1x150 WD VelociraptorCWindows1x150   WD Velociraptor
                    Burst  speedavg readBurst speadavg read
                    244106253104
                    DPagefile2x1TB Samsung Raid0DPagefile2x320GB   Raid0
                    Burst  speedavg readBurst  speedavg read
                    1158177347132
                    EProject12x1TB Samsung Raid30EProject6x1TB  WD Black Raid0
                    4272853966690
                    • 7. Re: PPBM4 Benchmark : Discussing my results...
                      Burst speed is quite dependant on how much cache the controller has, how much cache the disk drives have, the synthetic benchmark used to measure this data and the transfer rate of the controller to the system bus.  I do not put much faith in burst rate except if it is lower than "normal" it may mean a bottleneck in that specific system.
                      • 8. Re: PPBM4 Benchmark : Discussing my results...
                        A couple of things about above quote:
                        1. You wrote yourself:
                          So you are saying this is a disk issue.  So I am (in the first place) comparing the disk setups.
                          Not that I only want to focus on that off course... on the contrary if out of this topic we find other intersting tweaks that would be great of course.
                          So let me just for a couple of seconds think about burst speed and what you wrote above... in point 2. and 3.
                        2. My Raid controller ARC-1220 has 256MB Cache Memory and supports 8*SATA II.  I have inserted the controller into my x8 PCI-E slot (so using the max potential)
                          Harm his ARC-1680ix-12 controller has a default of 512MB Cache which is twice my amount of cache I agree.
                          His controller however also only supports PCI-E x8 so no speed gain on that.
                          So the only difference would be the double amount of cache.
                          But that is only for his 12 disc Raid30 volume.
                          This controller only support 12 disks internally so his 2x1TB raid0 must be configured (just like me) on the motherboards raid controller and we have the same motherboard, Asus P6T, so I can still not believe that he would have 1158 Burst speed on his 2x1TB RAID0 disks
                        3. This still does not explain why our Export AVI stats are so bad.
                          If you look at the charts on the http://ppbm4.com/Benchmark.html website there are people with much worse disk setups that have like 3 times better values for the Export AVI results.
                          I don't think my HDTach results are bad unless you consider Harm did not write a type error and his 2x1TB RAID0 disk burst speed is considered normal.
                        Thanks for thinking with me
                        • 9. Re: PPBM4 Benchmark : Discussing my results...
                          Sorry, but Harm has an ugraded Areca with 2 GB of cache.  With newer Areca's you can now even go to 4 GB
                          I have a second Areca and it has currently 512 MB of RAM.  Shortly I will be upgrading to 2 GB and will report the differences.
                          • 10. Re: PPBM4 Benchmark : Discussing my results...
                            That could be but still that would only explain the HDTach results for his 12x1TB Raid30 volume... not for his 2x1TB in raid0.
                            And that still does not explain why myself and some others have so bad numbers for AVI Export since other users (in the spreadsheet) have 'worse' disk setups and 3 times better AVI Export results... which was the main reason I opened this topic.
                            And off course Harm is 'leader' in this... it is not my intention to measure myself with him... I only put his stats against mine to see if there was a problem with my disks HDTach results.
                            • 11. Re: PPBM4 Benchmark : Discussing my results...
                              You are both correct and wrong.
                              Correct in that the raid0 burst results are strange, they appear too high, but that is what HDTach reported.
                              Wrong in exchanging the burst-rates for my raid0 and my raid30. There was no mix-up and yes, I was as surprised as you that the burst rate was that low on my raid30, but that is what HDTach gave me as results. On a side note, you will be hard pressed to find consistent and comparable test results when you ruin these tests a number of times. There will be meaningful differences between tests. So the message is, do not stare at the results too much but consider them as indicative of your systems performance.
                              Your average read speed with 6 x raid0 is about the maximum achievable (6 x 115 = 690 MB/s)  with nearly empty disks and negligent overhead. That is a fantastic score.
                              BTW: I had a disk crash on my notebook, which took my attention with reformatting/reinstalling/etc. and that is why I did not respond to your other post. I hope you can understand...
                              • 12. Re: PPBM4 Benchmark : Discussing my results...
                                Thanks for clarification...
                                Strange that you have such strange HDTach results.
                                Like I wrote earlier there are other persons in the benchmark chart that have worse disk setups than mine.  And you just confirmed there is nothing wrong with my disk setup and performance.
                                So that being out of the way... which other directions can we go from here to see where the bottleneck for these poor AVI Export ratings lies?
                                As I wrote before:
                                - This is a fresh install
                                - All disks are as good as empty and defragmented just before I run the benchmark
                                - A lot of Windows services are disabled and stopped (see lists above)
                                - No virusscanner installed and the firewall is turned off during the test
                                BTW: don't worry ... I don't mind you only were able to reply today... I am not expecting any reply withing the hour ;-) . To be honest I find the response times on this forum very correct. And I appreciate your and others help very much...
                                • 13. Re: PPBM4 Benchmark : Discussing my results...
                                  Welcome to the world of sometimes weird and sometimes wonderful results.  While Harm was fighting his notebook disk problems I had a memory module and a fan fail in my Internet computer while I am experimenting bringing up a third computer (a new --for me i7-920).  In the meantime I am trying to find out why I cannot repeat my data and now I am getting slightly slower results from PPBM4 with 4.2 Premiere than I did with 4.1 and in addition fighting eccentric behavior with conditional formatting in Excel and saving to the data to html (for the results page).
                                  One thing that is missing from the PPBM4 information is just exactly how some of these people are getting their RAID--i.e. what controller are they using.
                                  Just to show you how things can change here is a test I ran with 'Windows 7 RC and two different nVidia driver versions.
                                  • 14. Re: PPBM4 Benchmark : Discussing my results...
                                    That is strange Bill... what has a graphic driver to do with disk performance...
                                    I don't think the graphic driver had any influence... I am more thinking about:
                                    • the big time laps between you taking these 2 stats (more then a day between)
                                    • how much did the content of your disk change: a lot of data changes occured, fragmentation , ...
                                    • what other services ran during that time (there might be a big difference)
                                    • did you take the test right after booting up or did you work for a while
                                    • ... etc....
                                    And if we look at your stats that is a difference of roughly 15% but which could be explained by above points.
                                    That would still not explain why my AVI stats are > 300% slower than comparable or less performant setups.
                                    You are right type and setup of the controller will play a big deal... but also how you formatted your disks ( NTFS cluster size etc. )
                                    So you might want to add that to your chart to have better comparisons.
                                    • 15. Re: PPBM4 Benchmark : Discussing my results...
                                      Well those video driver tests were done in the same setting.  Absolutely the only thing that changed was the drivers.  This was done when some rumors were circulated about new graphics drivers "hogging" the PCIe bus.
                                      Edit: I just took a look at the date and time on HDtach.  They were done on sucessive dates (July 1st and 2nd 2009) but since they were done on my editing computer it is only turned on when editing or benchmarking.  If I remember correctly this was done with the Quadro FX1700 and before Areca had a Win 7 driver.  That accounts for the higher than currently posted AVI encoding times.  But it does show that the slower array performance does cause a slower encoding time.
                                      P.S. When benchmarking I defragment generally at least daily if not more often
                                      • 16. Re: PPBM4 Benchmark : Discussing my results...
                                        That does indeed make sense :  the graphic card is sitting on the same pci-e bus as your raid controllers is.
                                        But that would still not explain why my AVI stats are > 200%-300% slower than comparable or less performant hardware setups:
                                            * You wrote AVI is mainly disk speed.
                                            * Disk speed could be influenced by the graphic driver so that would/could explain 10-15% difference but ot all the rest.
                                        Let us take for example Ozzi (Ann).  She hits a score of 2.8 for AVI compared to my 4.5 with a lesser CPU and only 2 disks in Raid0.
                                        I am pretty sure my disks are 2-3 times faster than hers. So where does that difference come from...
                                        Is there anything I can tune further (running services, other windows tweaks, ... )
                                        • 17. Re: PPBM4 Benchmark : Discussing my results...
                                          EDIT!!!!
                                          Sorry I slipped to a wrong line when I looked at your graphics card but try going back to an earlier driver.
