0 Replies Latest reply on Jan 9, 2010 6:59 PM by Peter Farland
    [svn:fx-4.0.0] 13405: Given Sameer' s change in revision 13393 to remove spark.swc' s dependency on datavisualization.swc, we should enforce this by removing the reference in build scripts when building spark .swc.
    Peter Farland Level 3
      Revision: 13405
      Revision: 13405
      Author:   pfarland@adobe.com
      Date:     2010-01-09 18:59:37 -0800 (Sat, 09 Jan 2010)
      Log Message:
      Given Sameer's change in revision 13393 to remove spark.swc's dependency on datavisualization.swc, we should enforce this by removing the reference in build scripts when building spark.swc.
      Also updating the spark.swc sample Eclipse project to reflect this change in dependency (and correct the default linkage to external).
      QE notes: N/A
      Doc notes: N/A
      Bugs: FLEXDMV-2293 - Remove spark.swc's dependency on datavisualization.swc
      Reviewer: For Sameer
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/FLEXDMV-2293
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/spark/.actionScriptProperties
          flex/sdk/branches/4.0.0/frameworks/projects/spark/build.xml
