2 Replies Latest reply on Jan 10, 2010 10:19 PM by Flex harUI
    Accessing module's function via its parent
    andreamesser Level 1
      I have a module I inserted with moduleLoader and inside the module I'm trying to have one its functions run but I keep getting an undefined error.
      How can I access a function in a module from the parent. I have tried a couple different method and have even gotten to the point where no problem is identified until runtime.
      Below I have included the code for the application.
      Thanks in advance for any help you can provide.
      Justin
      Application Code below:
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" backgroundGradientAlphas="[1.0, 1.0]"
      backgroundGradientColors="
      [#008C69, #E3E0E0]" xmlns:comps="components.*" applicationComplete="init()">
      <mx:ApplicationControlBar dock="true" fillAlphas="[1.0, 1.0]" fillColors="[#E3E0E0, #E3E0E0]" themeColor="#008C69">
      <mx:MenuBar id="myMenu" dataProvider="{xLocations}" labelField="@label" itemClick="itemClickHandler(event)" fillAlphas="[1.0, 1.0]" fillColors="[#E3E0E0, #E3E0E0]" color="#3D3D3D">
      </mx:MenuBar>
      </mx:ApplicationControlBar>
      <comps:MyComponent y="525" x="407">
      </comps:MyComponent>
      <mx:Script>
      <![CDATA[
      import mx.modules.Module;
      import mx.events.MenuEvent;
      import mx.validators.ValidationResult;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.events.FaultEvent;
      import mx.controls.Alert;
      import flash.events.Event;
      import flash.net.URLLoader;
      import flash.net.URLRequest;
      import mx.modules.ModuleLoader;
      import mx.modules.ModuleManager;
      import mx.modules.IModuleInfo;
      import modules.survey;
      Bindable]
      private var myModule:survey;
      Bindable]
      private var xLocations:XMLList;
      Bindable]
      private var a:String;
      private function init():void {
      xmlService.send();
      xmlMenu.send();
      private function loaderInit():void
      myModule.treeMenu.send();
      private function getList():void {
      public function loadXML():void
      //var xmlLoader:URLLoader = new URLLoader();
      //xmlLoader.load(new URLRequest("http://www.visualdemocracy.com/xml.php"));
      //xmlLoader.addEventListener(Event.COMPLETE, handleLoad);
      public function handleLoad(event:Event):void
      // Result handler - gets called after RSS is loaded.
      private function resultHandler(event:ResultEvent):void
      xLocations = event.result.section;
      // Fault handler - displays the error.
      private function faultHandler(event:FaultEvent):void
      Alert.show(
      "Data errors");
      // Data verification
      private function correctHandler(event:FaultEvent):void
      Alert.show(
      "The data matches");
      private function itemClickHandler(event:MenuEvent):void
      var selectedMenu:XML = event.item as XML;
      trace("You selected" + selectedMenu.@label);
      public function createModule(m:ModuleLoader, s:String):void {
      if (!m.url)
      m.url = s;
      return;
      m.loadModule();
      public function removeModule(m:ModuleLoader):void {
      m.unloadModule();
      </mx:Script>
      <mx:HTTPService id="xmlService"
      url="
      data/invoices.xml"
      result="resultHandler(event)"
      resultFormat="
      e4x"/>
      <mx:HTTPService id="xmlMenu"
      url="
      data/menu.xml"
      resultFormat="
      e4x"/>
      <mx:Button label="Change Data" x="435" y="555"/>
      <mx:Button label="Get List" click="getList()" x="451" y="525"/>
      <mx:ModuleLoader id="mainLoader" x="10" y="10" url="modules/survey.swf" width="800" height="500" ready="loaderInit()">
      </mx:ModuleLoader>
      <mx:Canvas x="10" y="417" width="400" height="100" backgroundColor="#FFFFFF" cornerRadius="5" borderColor="#FFFFFF">
      </mx:Canvas>
      </mx:Application>
