6 Replies Latest reply on Jan 12, 2010 8:03 AM by tfcenturion
    StyleManager.getStyleDeclaration in a static function
    tfcenturion
      Hi Everyone,
      I have been watching these 360|Flex conference videos these last few days and i have tryed using some of the code found in them to varing success.
      One code example i am trying to get to work, is from Ben Clinkinbeard on creating reusable components.
      The code reads like:
      private static var stylesInited:Boolean = initStyles();
      private static function initStyles():Boolean
           // check for existence of style declaration
           var selector:CSSStyleDeclaration = StyleManager.getStyleDeclaration("LoginForm");
           // if one does not exist create it
           if(!selector)
                selector = new CSSStyleDeclaration();
           // set default style properties - don't use setStyle()!
           selector.defaultFactory = function():void
                // built-in styles
                this.backgroundAlpha = 1;
                this.backgroundColor = 0xDEDEDE;
                this.paddingTop = this.paddingRight = this.paddingBottom = this.paddingLeft = 10;
                // custom style
                this.inputColor = 0xFFFFFF;
           // apply defined styles
           StyleManager.setStyleDeclaration("LoginForm", selector, false);
           return true;
      My question is this, can you or is there a way i can place the styleName passed to this instead of hard coding a selector id.
      eg:
      var selector:CSSStyleDeclaration = StyleManager.getStyleDeclaration(this.styleName);
      I have tryed the above but i get a complier error about you cant use this keyword in a static function.
      I do think i need to have this as dynamic as i would like to createa a component that would have several instances of it on the stage with differant styles.
      If anyone could help on this or point me in the right direction i would be greatfull.
      Paul
        • 1. Re: StyleManager.getStyleDeclaration in a static function
          RUSH-ME
          Hi
          I think you can use the variable styleName in StyleManager.getStyleDeclaration();
          As we can't use this keyword in static function so its giving error. you can pass a variable like this.
          StyleManager.getStyleDeclaration(styleSelector);
          where "styleSelector" is the variable holding the style name.
          Hope this helps
          Rush-me
          • 2. Re: StyleManager.getStyleDeclaration in a static function
            tfcenturion Level 1
            Hi RUSH-ME,
            No that didnt work, i also tryed a function that just returned the selector as a string but to no avail there either.
            I get the error 'Access of undefined property' or 'Access of undefined function'.
            Any more thoughts..
            TFC
            • 3. Re: StyleManager.getStyleDeclaration in a static function
              RUSH-ME Level 3
              Hi
              Can you post your code updated code.
              I have done in that way and its working fine.
              Warm Regards
              Rush-me
              • 4. Re: StyleManager.getStyleDeclaration in a static function
                tfcenturion Level 1
                Hi RUSH-ME,
                Sure, the code i posted fisrt was from Ben's demo but mines basic same.
                package{.... blah blah
                protected var _styleName:String;
                public function ImageButton()
                     super();
                     _styleName = String(this.styleName);
                     trace("_styleName: ", _styleName);
                        // Check for existence of style declaration. //
                     var styles:CSSStyleDeclaration = StyleManager.getStyleDeclaration( "." + _styleName );
                     if(!styles)
                     { styles = new CSSStyleDeclaration("styles"); }
                     // Create All the default Styles we need. //
                     styles.defaultFactory = function():void
                          trace("initStyles(): Applying Custom Styles.");
                          // Built-In Styles. //
                          // Custom Styles. //
                          this.imagePadding = 15;
                     // Apply Defined Styles. //
                     StyleManager.setStyleDeclaration("." + _styleName, styles, false);
                     //this.setStyle("imagePadding", 40);
                     trace("initStyles():", styles.getStyle( "imagePadding" ));
                     return true;
                If i got the wrong end of the stick, could you post a small example/code to show the way.
                Thank you  on this.
                TFC
                • 5. Re: StyleManager.getStyleDeclaration in a static function
                  RUSH-ME Level 3
                  Hi
                  public
                  static function createStyle(styleSelector:String):CSSStyleDeclaration
                  var style:CSSStyleDeclaration = StyleManager.getStyleDeclaration(styleSelector);
                  if (!style)
                  style =
                  StyleManager.setStyleDeclaration(styleSelector, style,
                  false);
                  return style;
                  You can pass static variable to this function and create a style.
                  Hope this helps.
                  Rush-me
                  • 6. Re: StyleManager.getStyleDeclaration in a static function
                    tfcenturion Level 1
                    Hi there RUSH-ME,
                    Cheers for clearing that one, yes once i switched it to a function parameter it passed through ok.
                    Thank you .
                    TFC
