0 Replies Latest reply on Oct 8, 2006 3:22 AM by Newsgroup_User
    Tree Menu Component - Newbie
    Level 7
      HI all,
      I followed the following Adobe Tutorial to build my first Tree component:
      To load XML from an external file:
      http://livedocs.macromedia.com/flash/mx2004/main_7_2/wwhelp/wwhimpl/common/html/wwhelp.htm ?context=Flash_MX_2004&file=00002873.html
      Well this is a 4 step procedure.
      1) Adding component to the stage and name it "myTree".
      2)Make your XML file
      3) Adding action to 1st frame to load XML file
      4)Compile F12
      When i compile i get the error:
      Error opening URL "file:///F|/Eigene%20dateien/flash%20sources/treeXML.xml"
      All the files are in the same folder and there is nothing wrong with the XML
      file:
      <node>
      <node label="My Bookmarks">
      <node label="Macromedia Web site" url=" http://www.macromedia.com" />
      <node label="MXNA blog aggregator" url=" http://www.markme.com/mxna" />
      </node>
      <node label="Google" url=" http://www.google.com" />
      </node>
      I also tried to open the generated .swf file directly which offcourse shows
      nothing but "undefined"
      What am i doing wrong? Any help would be appreciated.
      Thank you
