0 Replies Latest reply on Jan 10, 2010 8:25 PM by Chet Haase
    [svn:fx-4.0.0] 13411: Fixed RTE with BitmapUtil.getSnapshot().
    Chet Haase Level 3
      Revision: 13411
      Revision: 13411
      Author:   chaase@adobe.com
      Date:     2010-01-10 20:24:16 -0800 (Sun, 10 Jan 2010)
      Log Message:
      Fixed RTE with BitmapUtil.getSnapshot(). We were not detecting cases of empty/transparent target objects and the capture logic would keep creating successively larger bitmaps in a vain attempt to capture the nontransparent bits. The fix was easy - objects with 0-dimension visual bounds should return null for the bitmap.
      QE notes: None
      Doc notes: None
      Bugs: sdk-24969
      Reviewer: Jason
      Tests run: checkintests, Mustella spark/effects/Wipe|CrossFade|AnimateShaderTransition
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-24969
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/utils/BitmapUtil.as
