0 Replies Latest reply on Jan 11, 2010 5:10 AM by Gellidus
    xmlSocket.onXML and xmlSocket.onData problem
    Gellidus
      I am having a problem with reading information that is being passed from a C# server. When I use xmlSocket.onXML, the xml object being passed from the server does not have any elements at all. When I use xmlSockt.onData, I am able to get the following output with tace:
      <?xml version="1.0"?>
      <Packet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
        <UserID>5555</UserID>
        <UserName>Success</UserName>
        <Operation>RefreshUsers</Operation>
      </Packet>
      However, when I check the string variable that I used to store this string in debug mode, the value of the string is "". And when I try to create an XML object using var my_xml:XML = new XML(srcstring); I get the same problem as when I used the xmlSocket.onXML method. The xml object my_xml contains no elements at all.
      Can anyone help me out on this? Thank you.
