2 Replies Latest reply on Jan 11, 2010 12:32 PM by Hodmi
    Creating PDF Portfolio  in ES2.
    PraveenKumar D Level 1
      Hi  ,
      I have created DDX  file and  previewed the same in Assembler Descripter   editor , am  able to create PDF portfolio  and save it  into local system.
      The DDX  :
      <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
        <PDF result="Untitled 1">
            <Navigator source="mysrc"/>
            <ColorScheme scheme="pinkScheme"/>
            <PDF source="sourcePDF1"/>
            <PDF source="sourcePDF2"/>
        <?ddx-source-hint name="mysrc"?>
        <?ddx-source-hint name="sourcePDF1"?>
        <?ddx-source-hint name="sourcePDF2"?>
      Used above DDX  file to genarate  the PDF Portfolio thru Activity  "AssemblerService -  Invoke DDX ", I  hope I genarated the PDF Portfolio, but i  don't know how to   retrive  the  PDF portfolio from AssemblerResult output Variable.
      I  got same log files in both  cases ....So  assuming  that Process created PDF Portfolio.
      But I dont know how to  get the PDF portfolio from AssemblerResult and store into local system.
      Please help  me to get PDF Portfolio from AssemblerRequest  output variable.
      Attached AssemblerResult as attachment.
        • 1. Re: Creating PDF Portfolio  in ES2.
          AnkitY Level 2
          Please try this xpath "/process_data/assemblerResult/object/documents[1]". Assign this to a local document variable.
          Since AssemblerResult/object/documents is a map of successful documents from the DDX job. Another approach could be to use get-map-values-for-keys function.
          • 2. Re: Creating PDF Portfolio  in ES2.
            Hodmi Level 4
            I've always done it in a two step process (done all in one setValue operation):
            1 - assign the resulting documents to a Map[document] object using the xpath:
            /process_data/myMap =   /process_data/assemblerResult/object/documents
            2 - get the correct response from the map.  The map's key name will be the same as is in your DDX's result tag.  In your case "Untitled 1"
            /process_data/@myDoc = /process_data/myMap[@id="Untitled 1"]
            With ES2 you can include the /process_data/@myDoc right in the DDX
              <PDF result="process:///process_data/@myDoc">
