5 Replies Latest reply on Jan 18, 2010 10:15 AM by msakrejda
    Flex Builder no longer detects errors against Array class definition.
    Wim Hoskens
      Hello,
      I don't know if this is the correct forum to post this problem, but here goes.
      I've been developping a application using Flex Builder 3. Today I encountered a strange problem. When I use an Array variable in an Actionscript class, the compiler no longer detects errors against the class defenition. I only encountur this behaviour with the Array class. All other top level classes, seem to work. F.i. I can insert the following in some function:
      var a:Array = [1, 2, 3];
      var i:a.Len;
      After building the, I get no error report. When I run the application, the variable i gets the value 0.
      I tried cleaning the existing project. I created a new flex project from scratch. The problem remains.
      I haven't done any updates lately, f.i. flash player, java, ... the development environment hasn't changed as far as I know.
      Can someone give some tips regarding this problem? Thank you.
      Regards,
      Wim.
