0 Replies Latest reply on Jan 11, 2010 1:52 PM by Carol L. Frampton
    [svn:fx-4.0.0] 13424: TLF Build 588.
    Carol L. Frampton Level 2
      Revision: 13424
      Revision: 13424
      Author:   cframpto@adobe.com
      Date:     2010-01-11 13:52:17 -0800 (Mon, 11 Jan 2010)
      Log Message:
      TLF Build 588. Bug fix for Catalyst.
      Build 588
      • Fix 2519851, Pasted paragraph formatting attributes overriding the attributes in the paste-to paragraph.
      QE notes:
      Doc notes:
      Bugs: SDK-24883
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24883
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/air-config.xml
          flex/sdk/branches/4.0.0/frameworks/flex-config.xml
          flex/sdk/branches/4.0.0/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayo ut.xml
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/edit/TextFlo wEdit.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.588.swf
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.587.swf
