3 Replies Latest reply on Jan 12, 2010 6:20 PM by sstanleyau
    Indesign Dialog user interface - help with script
    DawidRuzica
      Hi , I am very new to apple script and found this web site forum here , maybe I can get help:)
      I am trying to write a script in apple script to pop up a dialog that would as user where to save that file he/she is working on
      here is my example non working script
      tell document 1
      set myName to name
      set myFirstColumnWidth to 150
      set myDialog to make dialog with properties {name:"Print"}
      tell myDialog
      tell (make dialog column)
      --First Panel Border start
      tell (make border panel)
      --Options for a text size
      set myTextSizeList to {"Folder1", "Folder2", "Folder3"}
      tell (make dialog row)
      make static text with properties {static label:"Book Title:", min width:myFirstColumnWidth}
      end tell
      set myTextSizeDropdown to make dropdown with properties {string list:myTextSizeList, selected index:5, min width:200}
      end tell
      end tell
      end tell
      end tell
      end tell
      end tell
      set myResult to show myDialog
      if myResult is true then
      if selected index of myTextSizeDropdown is 0 then
      save to "Server:Server Space:PDF1:" & myName
      else if selected index of myTextSizeDropdown is 1 then
      save to "Server:Server Space:PDF2:" & myName
      else if selected index of myTextSizeDropdown is 2 then
      save to "Server:Server Space:PDF3" & myName
      end if
      end if
      end tell
      end tell
      also any possibility to do save a copy in applescript ? that would be even better. Any help is very much appreciated.
      thank you
      Dawid
        • 1. Re: Indesign Dialog user interface - help with script
          sstanleyau Level 4
          Your problem is that you're trying to make the dialog at the document rather than application level. Try this:
          tell application "Adobe InDesign CS4"
          tell document 1
          set myName to name
          end tell
          tell myDialog
          end tell
          end tell
          end tell
          end tell
          end tell
          end tell
          end tell
          tell document 1
          end if
          end tell
          end if
          destroy myDialog
          end tell
          You can't do a copy save directly; you'd need to do a save, close the document, and reopen the original.
          • 2. Re: Indesign Dialog user interface - help with script
            DawidRuzica Level 1
            Yes that worked! Thank you very much.
            since I can not use save copy with applescript, how would I write a script to save original in current location (it already has a name and location) then do the above script (save as)
            close
            and here is what I don't know: "open that original again" ?
            thank you
            • 3. Re: Indesign Dialog user interface - help with script
              sstanleyau Level 4
              Roughly:
              set fullPath to full name of document 1
              save document 1 to fullPath
              -- do your save as here
              close document 1 saving no
              open fullPath
