1 Reply Latest reply on Jun 13, 2008 8:11 AM by matthew horn
    Multi-line chart axis titles?
    yantzgh Level 1
      I’m using the charting components provided with Flex Builder 3 Pro and can’t seem to get the y-axis title to display multi-line. I traced the code back to the ChartLabel.as class provided in the sdk and it shows that when the label is created, multi-line is set to true. Is there a special string I need to pass with the title to make it use 2 lines?
      The strings I’ve tried are…
      “% of e-mail users accessing e-mail eight or more times per month”
      “% of e-mail users accessing e-mail\neight or more times per month”
      “% of e-mail users accessing e-mail<br>eight or more times per month”
      …but each still displays on a single line.
        • 1. Multi-line chart axis titles?
          matthew horn Level 3
          You should be able to force a multi line axis label by using "\n" in the title, and setting its value in actionscript rather than as a property of the axis tag, like this:
          myLinearAxis.title="Dollars \n for \n Donuts";
          renders as:
          Dollars
          for
          Donuts
          hth,
          matt horn
          flex docs
