0 Replies Latest reply on Jan 12, 2010 6:14 AM by Carol L. Frampton
    [svn:fx-4.0.0] 13440: If htmlTest is set, composeHtmlText is called each time the text lines are invalidated.
    Carol L. Frampton Level 2
      Revision: 13440
      Revision: 13440
      Author:   cframpto@adobe.com
      Date:     2010-01-12 06:14:43 -0800 (Tue, 12 Jan 2010)
      Log Message:
      If htmlTest is set, composeHtmlText is called each time the text lines are invalidated.  Many of the setters invalidate the text lines.  Since composeHtmlText() sets _htmlText to null (unless there is a style sheet), we need to save the original htmlText so we can use it to regenerate the text lines.  If _htmlText is used, and it is null, no text lines will be generated.
      QE notes: related to SDK-24877 so retest and need to add htmlText with styleSheet tests
      Doc notes:
      Bugs: SDK-23567
      Reviewer: Gordon
      Tests run: SDK-24877, FTETextField
      Is noteworthy for integration:
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24877
          http://bugs.adobe.com/jira/browse/SDK-23567
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/mx/core/FTETextField.as
