3 Replies Latest reply on Jan 13, 2010 1:54 AM by hari_kdr
    How to change Color in gradient by easiest way
    hari_kdr Level 1
      Hi Guys,
      Please find attached files. In that file we have lot of gradients. Those gradients hasbeen built with Magenta Color with different persentages. Now I need to change that Magenta color with PMS 219 C with same persentages.
      That mean If Magenta has in 25% now that color should be PMS 219C  25%. like this I need to chage with PMS color every where with same persentages.
      This kind of files I have a lot. So I am requesting you people to give a good solution to change easily...
      Thanks in advance...
      HARI
        • 1. Re: How to change Color in gradient by easiest way
          JETalmage Level 6
          You used only percentages of process Magenta in the color stops of your grads. So, for example, the grad in the leftmost object has five color stops, each being a different process color. To Illustrator, it makes no difference that those five different process colors contain only values of the same single CMYK component (Magenta); to Illustrator, they are five different process colors.
          If you had first defined a Global process Swatch containing only 100% Magenta, and then used tints of that Global Swatch in your grads, then you could simply change that Global Swatch to Spot, and then replace that Spot with another (219C), and the grad Swatches and objects using tints of the original Global Swatch would update accordingly.
          I'm not defending Illustrator's convoluted color handling, I'm just telling you how it is. Illustrator's Global vs. non-Global color distinction is nonsense. It should be done away with, and all colors defined as Swatches should act as Global.
          You don't say what version Illustrator you are using. Assuming CS3 or newer, you can:
          1. Add a new Swatch for 219.
          2. Select All.
          3. Edit>Adjust Colors>Recolor Artwork.
          4. Colors popup: 1.
          5. DoubleClick the color icon under the New column.
          6. In the resulting Color Picker, click the Swatches button.
          7. In the resulting Swatches list, click the Swatch for 219.
          8. Click OK and close the Live Color dialog.
          Now if you select one of the grad-filled objects, and click one of its color stops in the Gradient palette, you'll see by looking in the Color palette (Adobe, can we please have a few more different places to look to perform one simple operation?) that the color stop is now a tint of the spot color 219.
          JET
          • 2. Re: How to change Color in gradient by easiest way
            Scott Falkner Level 5
            Looks like lucky 13. Here’s 14 on the Mac…
            I think 12 and earlier used interface gadgets more like the standard OS and less like the Flash garbage they’re messing around with now.
            • 3. Re: How to change Color in gradient by easiest way
              hari_kdr Level 1
              Hi
              Thanks for the reply first...
              I tried with your guidance, but some where i am missing. I am not getting spot persentage. If I replace with 219 PMS also in gradient showing Magenta persentage. So kindly explain more detaily and if possible please give that file which you trid.
              HARI
