0 Replies Latest reply on Jan 12, 2010 7:43 AM by Carol L. Frampton
    [svn:fx-4.0.0] 13444: TLF Build 589.
    Carol L. Frampton Level 2
      Revision: 13444
      Revision: 13444
      Author:   cframpto@adobe.com
      Date:     2010-01-12 07:42:57 -0800 (Tue, 12 Jan 2010)
      Log Message:
      TLF Build 589.  Accept fixes for 2518934 and 2522433. Both are serious problems involving common use-cases of the IME and both have low-risk fixes that don't affect non-IME-related code paths.
      Build 589
      • Fix 2513232, IME conversion window comes up in the top left corner instead of under the text.
      • Fix 2522271, IME typing doesn't replace selected text.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/air-config.xml
          flex/sdk/branches/4.0.0/frameworks/flex-config.xml
          flex/sdk/branches/4.0.0/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayo ut.compose.xml
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayo ut.xml
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/compose/Text FlowLine.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClie nt.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.589.swf
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.588.swf
