1 Reply Latest reply on Jan 18, 2010 9:45 AM by devJT1
    Excercise 3
    vbangflex
      The flex debugger is not working and I am unable to figure out what is the problem with this excercise. Room names are not filled in the list control. Can anybody help me.
      In order flex debugger to work I uninstalled flash player and reinstalled flash player. I also installed debugger version. Nothing is helping me. Also I am getting actionscript erros. What is wrong with this? I am stuck with this from past one week. I am unable to go further. Please help me.
      vshree
      Here is my code
      ?xml version="1.0" encoding="utf-8"?>
      <mx:Application
      creationComplete="init()" xmlns:mx="http://www.adobe.com/2006/mxml"
      layout="
      absolute" backgroundColor="#FFFFFF">
      <mx:Script>
      <![CDATA[
      import mx.events.ListEvent;
      import mx.collections.ArrayCollection;
      import mx.rpc.events.FaultEvent;
      import mx.controls.Alert;
      import mx.rpc.events.ResultEvent;
      private function changeHandler(event:ListEvent):void{
      Bindable]
      private var roomList:ArrayCollection;
      private function init():void{
      rooms.send();
      private function httpFaultHandler(event:FaultEvent):void{
      Alert.show(
      "There was a problem", "Error");
      private function httpResultHandler(event:ResultEvent):void{
      roomList=event.result.rooms.room
      </mx:Script>
      <mx:HTTPService id="rooms" url="assets/roomList.xml" fault="httpFaultHandler(event)"/>
      <mx:Label text="XYZ Convention Center"
      x="
      10" y="10"
      fontSize="
      21" fontWeight="bold"/>
      <mx:Text x="10" y="41"
      text="
      111 49th Ave, Denver, CO 80634"/>
      <mx:Text text="Phone: 303-555-1212" x="208" y="41"/>
      <mx:Text text="Fax: 303-555-1234" x="345" y="41"/>
      <mx:Label text="Room Reservation System"
      fontWeight="
      bold" fontSize="14"
      x="
      10" y="72"/>
      <mx:Label text="Room Available:" x="10" y="108"/>
      <mx:List id="dg" x="10" y="134" width="250"
      dataProvider="
      {roomList}"
      itemClick="changeHandler(event)"
      labelField="
      name"/>
      </mx:Application>
        • 1. Re: Excercise 3
          devJT1 Level 1
          Hey Vshree,
          Try adding a semicolon to the end of the line within the httpResultHandler function like this,
              roomList=event.result.rooms.room;
          That should clear up the syntax error.
          Then, add the result event to the HTTPService tag,
                 result="httpResultHandler(event)"/>
          You should see the rooms populated within the List element.
          Hope this helps.
          Jeff
