5 Replies Latest reply on Jan 13, 2010 2:11 PM by [Jongware]
    Script to customize polygons?
    hpushinsky
      I am looking to make a rectangle with one point at a 30 degree angle.
      I was hoping to put together a script to automatically do this but am stumped.  Anyone know of a good resource for this?
      I understand how you can make a polygon using the Polygon Tool but this gives rotation from the center point of the shape.  I just want one angle.
      _________________
      |                             \  <--- where I'd like to have a 30 degree angle
      |__________________\
      Any help would be appreciated, my scripting level is zero but I'm up for learning!!
        • 1. Re: Script to customize polygons?
          AdobeScripts Level 3
          You can change PathPoint's position in Rectangle's Path. But when you do this - your Rectangle will change it's type to Polygon.
          If you tell us what platform and language you use/prefer - you could get sample code.
          robin
          www.adobescripts.com
          • 2. Re: Script to customize polygons?
            hpushinsky Level 1
            Changing the shape to Polygon is fine.  The only downside is not being able to center align text in the polygon but that's okay!  I am using VB Script.
            Thanks for your help! This will make life a lot easier I hope!
            • 3. Re: Script to customize polygons?
              The bottom right point should be moved to the right with tan(angle).
              This script first draws a regular rectangle (so I know where all the points are!), then moves the bottom right point:
              var height =  50;
              var width = 100;
              var xcenter = app.activeDocument.documentPreferences.pageWidth/2;
              var ycenter = app.activeDocument.documentPreferences.pageHeight/2;
              newrect = app.activeDocument.graphicLines.add ();
              newrect.strokeColor = app.activeDocument.swatches[2];     // Usually black ...
              newrect.strokeWeight = 1;
              // starting top left, going clockwise:
              newrect.paths[0].pathPoints[0].anchor = [xcenter - width/2, ycenter - height/2];
              newrect.paths[0].pathPoints[1].anchor = [xcenter + width/2, ycenter - height/2];
              newrect.paths[0].pathPoints.add({anchor:[xcenter + width/2, ycenter + height/2]});
              newrect.paths[0].pathPoints.add({anchor:[xcenter - width/2, ycenter + height/2]});
              newrect.paths[0].pathType = PathType.CLOSED_PATH;
              // adjust point #2 -- the bottom right one
              xpos = newrect.paths[0].pathPoints[2].anchor[0] + height*Math.tan(30*Math.PI/180);
              newrect.paths[0].pathPoints[2].anchor = [xpos, newrect.paths[0].pathPoints[2].anchor[1]];
              (The rectangle only has one single path -- paths[0]. The path consists of 4 pathPoints, and each pathPoint is defined by a single anchor, an array of [x, y]. For some reason, you cannot set just the x coordinate in the bottom line -- you have to supply a new array.)
              (Ed.: ... and I just saw your reply to Robin. This is Javascript, but you might be able to make it work in VB.)
              • 4. Re: Script to customize polygons?
                hpushinsky Level 1
                I don't want to have a specified rectangle, I'd like to apply the degree as more of a corner effect.  I tried incorporating the tangent code into the corner effects script below but it had an error.  How do I change the offset to be a degree?
                Rem CornerEffects.vbs
                Rem An InDesign CS3 VBScript
                Rem
                Rem Applies corner effects by redrawing the object.
                Rem
                Rem For more information on InDesign scripting, go to
                http://www.adobe.com/products/indesign/xml_scripting.html
                Rem Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com.
                Rem
                Set myInDesign = CreateObject("InDesign.Application.CS3")
                If myInDesign.Documents.Count > 0 Then
                    If myInDesign.Selection.Count > 0 Then
                        Set mySelection = myInDesign.Selection
                        ReDim myObjectList(0)
                        For myCounter = 1 To mySelection.Count
                            Select Case TypeName(mySelection.Item(myCounter))
                                Case "Rectangle", "Oval", "Polygon", "GraphicLine", "TextFrame"
                                    If Not (IsEmpty(myObjectList(0))) Then
                                        ReDim Preserve myObjectList(UBound(myObjectList) + 1)
                                    End If
                                    Set myObjectList(UBound(myObjectList)) = mySelection.Item(myCounter)
                                Case Else
                            End Select
                        Next
                            myDisplayDialog myInDesign, myObjectList
                        Else
                            MsgBox "Nothing is selected. Please select a rectangle, oval, polygon, text frame, or
                graphic line and try again."
                        End If
                    Else
                        MsgBox "Nothing is selected. Please select a rectangle, oval, polygon, text frame, or graphic
                    End If
                Else
                    MsgBox "Please open a document, select an object, and try again."
                End If
                Function myDisplayDialog(myInDesign, myObjectList)
                    myStringList = Array("all points", "first point", "last point", "second point", "third point",
                "fourth point", "first two", "second and third", "last two", "odd points", "even points")
                    Rem Store the current measurement units.
                    myOldXUnits = myInDesign.ActiveDocument.ViewPreferences.HorizontalMeasurementUnits
                    myOldYUnits = myInDesign.ActiveDocument.ViewPreferences.VerticalMeasurementUnits
                    Rem Set the measurement units to points.
                    myInDesign.ActiveDocument.ViewPreferences.HorizontalMeasurementUnits = idMeasurementUnits.idPoints
                    myInDesign.ActiveDocument.ViewPreferences.VerticalMeasurementUnits = idMeasurementUnits.idPoints
                    Set myDialog = myInDesign.Dialogs.Add
                    myDialog.Name = "CornerEffects"
                    With myDialog
                        With .DialogColumns.Add
                            With .BorderPanels.Add
                                With .StaticTexts.Add
                                    .StaticLabel = "Corner Type:"
                                End With
                                Set myCornerEffectButtons = .RadiobuttonGroups.Add
                                With myCornerEffectButtons
                                    With .RadiobuttonControls.Add
                                        .StaticLabel = "Rounded"
                                        .CheckedState = True
                                    End With
                                        .StaticLabel = "Inverse Rounded"
                                    End With
                                        .StaticLabel = "Bevel"
                                    End With
                                        .StaticLabel = "Inset"
                                    End With
                                        .StaticLabel = "Fancy"
                                    End With
                                End With
                            End With
                                        .StaticLabel = "Options:"
                                    End With
                                End With
                                    With .DialogRows.Add
                                                .StaticLabel = "Offset:"
                                                .MinWidth = 60
                                            End With
                                        End With
                                            Set myOffsetEditbox = .MeasurementEditboxes.Add
                                            With myOffsetEditbox
                                                .EditValue = 12
                                            End With
                                        End With
                                    End With
                                                .StaticLabel = "Pattern:"
                                                .MinWidth = 60
                                            End With
                                        End With
                                            Set myPatternDropdown = .Dropdowns.Add
                                            With myPatternDropdown
                                                .StringList = myStringList
                                                .SelectedIndex = 0
                                            End With
                                        End With
                                    End With
                                End With
                            End With
                        End With
                    End With
                    myReturn = myDialog.Show
                    If myReturn = True Then
                        Rem Get the values from the dialog box.
                        myCornerType = myCornerEffectButtons.SelectedButton
                        myOffset = myOffsetEditbox.EditValue
                        myPattern = myStringList(myPatternDropdown.SelectedIndex)
                        myDialog.Destroy
                        Rem Iterate through the objects.
                        For myCounter = 0 To UBound(myObjectList)
                            myChangeCorners myObjectList(myCounter), myCornerType, myOffset, myPattern
                        Next
                        Rem Reset the measurement units.
                        myInDesign.ActiveDocument.ViewPreferences.HorizontalMeasurementUnits = myOldXUnits
                        myInDesign.ActiveDocument.ViewPreferences.VerticalMeasurementUnits = myOldYUnits
                    Else
                        myDialog.Destroy
                    End If
                End Function
                Function myChangeCorners(myObject, myCornerType, myOffset, myPattern)
                    For myPathCounter = 1 To myObject.Paths.Count
                        Set myPath = myObject.Paths.Item(myPathCounter)
                        ReDim myPointArray(0)
                        For myPathPointCounter = 1 To myPath.PathPoints.Count
                            Rem Is the point a qualifying point?
                            If myPointTest(myPathPointCounter, myPath, myPattern) = False Then
                                myX1 = myPath.PathPoints.Item(myPathPointCounter).LeftDirection(0)
                                myY1 = myPath.PathPoints.Item(myPathPointCounter).LeftDirection(1)
                                myX2 = myPath.PathPoints.Item(myPathPointCounter).Anchor(0)
                                myY2 = myPath.PathPoints.Item(myPathPointCounter).Anchor(1)
                                myX3 = myPath.PathPoints.Item(myPathPointCounter).RightDirection(0)
                                myY3 = myPath.PathPoints.Item(myPathPointCounter).RightDirection(1)
                                myPoint = Array(Array(myX1, myY1), Array(myX2, myY2), Array(myX3, myY3))
                                If Not (IsEmpty(myPointArray(0))) Then
                                    ReDim Preserve myPointArray(UBound(myPointArray) + 1)
                                End If
                                myPointArray(UBound(myPointArray)) = myPoint
                            Else
                                Set myPointA = myPath.PathPoints.Item(myPathPointCounter)
                                myAnchor = myPointA.Anchor
                                myX1 = myAnchor(0)
                                myY1 = myAnchor(1)
                                Rem myPointB is the *next* point on the path. If myPathPoint is the last point on the
                path, then
                                Rem myPointB is the first point on the path.
                                If myPathPointCounter = (myPath.PathPoints.Count) Then
                                    Set myPointB = myPath.PathPoints.Item(1)
                                Else
                                    Set myPointB = myPath.PathPoints.Item(myPathPointCounter + 1)
                                End If
                                myAnchor = myPointB.Anchor
                                myX2 = myAnchor(0)
                                myY2 = myAnchor(1)
                                Rem myPointC is the *previous* point on the path. If myPathPoint is the first point on
                the path,
                                Rem then myPointC is the last point on the path.
                                If myPathPointCounter = 1 Then
                                    Set myPointC = myPath.PathPoints.Item(myPath.PathPoints.Count)
                                Else
                                    Set myPointC = myPath.PathPoints.Item(myPathPointCounter - 1)
                                End If
                                myAnchor = myPointC.Anchor
                                myX3 = myAnchor(0)
                                myY3 = myAnchor(1)
                                myPoints = myAddPoints(myX1, myY1, myX2, myY2, myX3, myY3, myOffset)
                                myNewX1 = myPoints(0)
                                myNewY1 = myPoints(1)
                                myNewX2 = myPoints(2)
                                myNewY2 = myPoints(3)
                                Rem Calculate new path point values based on the path effect type.
                                Rem We won't add the points to the path one at a time instead, we'll
                                Rem create an array that holds all of the point locations and curve
                                Rem handle positions, and we will then
                                Select Case myCornerType
                                    Case 0
                                        Rem Rounded corner effect.
                                        myPoint = Array(Array(myNewX2, myNewY2), Array(myNewX2, myNewY2), Array(myX1,
                myY1))
                                        myAddToArray myPointArray, myPoint
                                        myPoint = Array(Array(myNewX1, myNewY1), Array(myNewX1, myNewY1),
                Array(myNewX1, myNewY1))
                                    Case 1:
                                        Rem Inverse Rounded corner effect.
                Array(myNewX2 + myNewX1 - myX1, myNewY2 + myNewY1 - myY1))
                                    Case 2:
                                        Rem Bevel corner effect.
                Array(myNewX2, myNewY2))
                                    Case 3:
                                        Rem Inset corner effect.
                                        myPoint = Array(Array(myNewX2 + myNewX1 - myX1, myNewY2 + myNewY1 - myY1),
                Array(myNewX2 + myNewX1 - myX1, myNewY2 + myNewY1 - myY1), Array(myNewX2 + myNewX1 - myX1, myNewY2 +
                myNewY1 - myY1))
                                    Case 4:
                                        Rem Fancy corner effect.
                                        myOneThird = 0.33333333332
                                        myTwoThirds = 0.666666666667
                                        myPointZX = myNewX2 + myNewX1 - myX1
                                        myPointZY = myNewY2 + myNewY1 - myY1
                                        myTemp1X = (myX1 - myNewX2) * myTwoThirds
                                        myTemp1Y = (myY1 - myNewY2) * myTwoThirds
                                        myTemp2X = (myX1 - myNewX1) * myTwoThirds
                                        myTemp2Y = (myY1 - myNewY1) * myTwoThirds
                                        myPointDX = myPointZX + myOneThird * (myNewX1 - myPointZX)
                                        myPointDY = myPointZY + myOneThird * (myNewY1 - myPointZY)
                                        myPointEX = myPointZX + myOneThird * (myNewX2 - myPointZX)
                                        myPointEY = myPointZY + myOneThird * (myNewY2 - myPointZY)
                                        myPointFX = myPointDX + myTwoThirds * (myX1 - myTemp1X - myPointDX)
                                        myPointFY = myPointDY + myTwoThirds * (myY1 - myTemp1Y - myPointDY)
                                        myPointGX = myPointEX + myTwoThirds * (myX1 - myTemp2X - myPointEX)
                                        myPointGY = myPointEY + myTwoThirds * (myY1 - myTemp2Y - myPointEY)
                                        myPointHX = myPointZX + myTemp1X + myTemp2X
                                        myPointHY = myPointZY + myTemp1Y + myTemp2Y
                                        myPoint = Array(Array(myPointEX, myPointEY), Array(myPointEX, myPointEY),
                Array(myPointEX, myPointEY))
                                        myPoint = Array(Array(myPointGX, myPointGY), Array(myPointGX, myPointGY),
                Array(myPointGX, myPointGY))
                                        myPoint = Array(Array(myPointHX, myPointHY), Array(myPointHX, myPointHY),
                Array(myPointHX, myPointHY))
                                        myPoint = Array(Array(myPointFX, myPointFY), Array(myPointFX, myPointFY),
                Array(myPointFX, myPointFY))
                                        myPoint = Array(Array(myPointDX, myPointDY), Array(myPointDX, myPointDY),
                Array(myPointDX, myPointDY))
                                End Select
                            End If
                        Next
                        myPath.EntirePath = myPointArray
                    Next
                End Function
                Function myAddPoints(myX1, myY1, myX2, myY2, myX3, myY3, myOffset)
                    myHypotenuse = Sqr(((myX1 - myX2) ^ 2) + ((myY1 - myY2) ^ 2))
                    If myY1 <> myY2 Then
                        myXAdjust = ((myX1 - myX2) / myHypotenuse) * myOffset
                        myYAdjust = ((myY1 - myY2) / myHypotenuse) * myOffset
                        myNewX1 = myX1 - myXAdjust
                        myNewY1 = myY1 - myYAdjust
                    Else
                        myXAdjust = myOffset
                        myYAdjust = 0
                        If myX1 < myX2 Then
                            myNewX1 = myX1 + myXAdjust
                            myNewY1 = myY1 + myYAdjust
                        Else
                        End If
                    End If
                    myHypotenuse = Sqr(((myX1 - myX3) ^ 2) + ((myY1 - myY3) ^ 2))
                    If myY1 <> myY3 Then
                        myXAdjust = ((myX1 - myX3) / myHypotenuse) * myOffset
                        myYAdjust = ((myY1 - myY3) / myHypotenuse) * myOffset
                        myNewX2 = myX1 - myXAdjust
                        myNewY2 = myY1 - myYAdjust
                    Else
                        myYAdjust = 0
                        If myX1 < myX3 Then
                            myNewX2 = myX1 + myXAdjust
                            myNewY2 = myY1 + myYAdjust
                        Else
                        End If
                    End If
                    myAddPoints = Array(myNewX1, myNewY1, myNewX2, myNewY2)
                End Function
                Function myPointTest(myPathPointCounter, myPath, myPattern)
                    Rem Do not apply the corner effect to the first or last point in an open path
                    Rem (this is the way that InDesign's corner effects work).
                    If ((myPath.PathType = idPathType.idOpenPath) And ((myPathPointCounter = 0) Or (myPathPointCounter
                = myPath.PathPoints.Count))) Then
                        myPointTest = False
                        Exit Function
                    Else
                        Select Case myPattern
                            Case "all points"
                                myPointTest = True
                                Exit Function
                            Case "first point":
                                If myPathPointCounter = 0 Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "last point":
                                If myPathPointCounter = myPath.PathPoints.Count Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "second point":
                                If myPathPointCounter = 2 Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "third point":
                                If myPathPointCounter = 3 Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "fourth point":
                                If myPathPointCounter = 4 Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "first two":
                                If ((myPathPointCounter = 1) Or (myPathPointCounter = 2)) Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "second and third":
                                If ((myPathPointCounter = 2) Or (myPathPointCounter = 3)) Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "last two":
                                If ((myPathPointCounter = myPath.PathPoints.Count) Or (myPathPointCounter =
                (myPath.PathPoints.Count - 1))) Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "even points":
                                If myPathPointCounter Mod 2 = 0 Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                            Case "odd points":
                                If myPathPointCounter Mod 2 <> 0 Then
                                    myPointTest = True
                                    Exit Function
                                Else
                                    myPointTest = False
                                    Exit Function
                                End If
                        End Select
                    End If
                End Function
                Function myAddToArray(myArray, myItem)
                    If Not (IsEmpty(myArray(0))) Then
                        ReDim Preserve myArray(UBound(myArray) + 1)
                    End If
                    If Not (IsObject(myItem)) Then
                        myArray(UBound(myArray)) = myItem
                    Else
                        Set myArray(UBound(myArray)) = myItem
                    End If
                End Function
                • 5. Re: Script to customize polygons?
                  You might need to think this through a bit. You need to move the point horizontally or vertically (or both) to change the angle. I bet this is not what you had in mind:
