4 Replies Latest reply on Jan 13, 2010 5:03 AM by James Newton, ACP
    Buttons and Sprites
    Stuart Gloucester
      Hi - I want to create a button in Director that will remove a sprite from the stage. I also want this same button to return the sprite to the stage when I click on it again. I have looked in the Lib palette and behaviours and can see anything suitable. Can this be done with some script?
      Thankyou
      Stuart
        • 1. Re: Buttons and Sprites
          Chunick Level 3
          Yes, it can be done.
          You don't mention which version of Director you are using, but I'll assume DMX2004 or higher. Try out the makeScriptedSprite() and removeScriptedSprite() methods, or you can simply move the sprite off and on stage by changing it's .loc property.
          • 2. Re: Buttons and Sprites
            Stuart Gloucester Level 1
            Hi Joshua
            I am using version 8.5
            Just tried what what said, and a script error is returned for removeScripted
            Any ideas??
            The change location wont work as I want to be able to click on one button and remove something else.
            Stuart
            • 3. Re: Buttons and Sprites
              Mike Blaustein Level 4
              the scriptedSprite stuff did not exist in version 8.5.  Back then you would use puppetSprite to create a "temporary" sprite on the stage, and to remove it.  But I think that you are trying to take the hard way by actually creating and destroying the sprite.  As Josh mentioned, it is much easier to simply move the sprite off the stage when you want it gone. Then the user can't see it, so it appears to have been destroyed.  You can also change the blend of the sprite to 0, or set the visible of the channel to false in order to hide a sprite.  It all depends upon what you need to do specifically.
              • 4. Re: Buttons and Sprites
                James Newton, ACP Level 3
                Here's a behavior that you can attach to the sprite that you wish to remove from the stage:
                -- SHOW AND HIDE --
                -- Behavior
                -- Attach this behavior to a graphic sprite.
                -- 091229 JN: ShowHide_Toggle() now only sets the rect of the sprite
                --            the rect is to change.
                -- PROPERTY DECLARATIONS --
                property hideOnBeginSprite  -- if TRUE, then sprite is moved offstage
                property pSprite            -- pointer to this sprite
                property pOnRect            -- initial (on-stage) rect of this sprite
                property pOffRect           -- rect which places this sprite off-stage
                -- SPRITE EVENTS --
                on beginSprite(me) ---------------------------------------------------
                  -- ACTION: Initializes properties
                  pSprite = sprite(me.spriteNum)
                  pOnRect = pSprite.rect
                  pOffRect = pOnRect.offset(-pOnRect.right, 0)
                  if hideOnBeginSprite then
                    me.ShowHide_Toggle(#hide)
                  end if
                end beginSprite
                -- PUBLIC METHOD --
                on ShowHide_Toggle(me, aShow) ----------------------------------------
                  -- INPUT: <aShow> is considered TRUE if it is VOID or 1, FALSE for
                  --         any other value
                  -- ACTION: ShowHide_Toggle() and ShowHide_Toggle(1) will replace
                  --         this sprite in its starting position. ShowHide_Toggle(0),
                  --         ShowHide_Toggle(#hide) or any other value will move it
                  --         off-stage.
                  if voidP(aShow) or (aShow = TRUE) then
                    vRect = pOnRect
                  else
                    vRect = pOffRect
                  end if
                  if pSprite.rect <> vRect then
                    pSprite.rect = vRect
                  end if
                end ShowHide_Toggle
                -- BEHAVIOR PARAMETERS --
                on getPropertyDescriptionList(me)
                  vPropertyList = [:]
                  vPropertyList[ \
                #hideOnBeginSprite] = [ \
                #comment: "Hide on beginSprite", \
                #format:   #boolean, \
                #default:  FALSE]
                  return vPropertyList
                end getPropertyDescriptionList
                From your button, you can use sendSprite(<spriteNum>, #ShowHide_Toggle, <TRUE or FALSE>)
