3 Replies Latest reply on Jan 13, 2010 4:29 AM by Francisc
    Reference Parent Public Vars/Methods
    Francisc Level 3
      Hello!
      How can I reference a TitleWindow's parent's public variables or functions?
      The TitleWindow is opened as a Window using the PopUpManager Class.
      Thank you!
        • 1. Re: Reference Parent Public Vars/Methods
          RUSH-ME Level 3
          Hi
          There is a parent property available for TitleWindow.
          By typecasting it to your parent class you can call public functions.
          Hope this helps
          Rush-me
          • 2. Re: Reference Parent Public Vars/Methods
            archemedia Level 4
            Or, you could reference the TitleWindow in some variable prior to opening it in the PopupManager:
            In your main app:
            public var tw:TitleWindow;
            Somewhere inside your app:
            this.parentApplication.tw = PopUpManager.createPopUp(this, TitleWindow) as TitleWindow;
            PopUpManager.centerPopUp(this.parentApplication.tw);
            now you can address all the public properties of the window using the reference 'tw'.
            TIP: If you have to hold global variables for use in your application, you'd better create a singleton Class with all these variables.
            From anywhere in your application, you can then call MyGlobalClass.getInstance().myVar.
            If you don't know what I'm talking about, let me know so I can post an example
            d
            • 3. Re: Reference Parent Public Vars/Methods
              Francisc Level 3
              Thank you both.
              I've used the less-code method Rush-Me posted, only using Application.application.myVar etc.
