5 Replies Latest reply on Jan 15, 2010 2:19 AM by harsh_hot
    how to iterate over a tree
    harsh_hot Level 1
      Hi friends,
      I am new to flex and hence need your help in a problem.I am getting an xmllist through httpservice and now i want to iterate over this list so as to access individual nodes but i am unable to figure out a way. Please suggest me how do i iterate over nodes using httpservice and xmllistcollection.
        • 1. Re: how to iterate over a tree
          Gregory Lafrance Level 6
          After you get the data back from your HTTPService (set its resultFormat property to e4x), use e4x syntax to access the data.
          If this is your data myXML:
          <items>
              <item>
                  <name>test1</name>
                  <addr>test address1</addr>
              </item>
              <item>
                  <name>test2</name>
                  <addr>test address2</addr>
              </item>
              <item>
                  <name>test3</name>
                  <addr>test address3</addr>
              </item>
          </items>
          then you can access the data and assign to a data provider with:
          myXmlListCollection = new XMLListCollection(myXML..item);
          You can loop through the data lie this:
          for each(var xml:XML in myXML..item){
            trace(xml.toXMLString());
          http://livedocs.adobe.com/flex/3/html/help.html?content=13_Working_with_XML_03.html
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: how to iterate over a tree
            harsh_hot Level 1
            Thanks Greg for the reply but it could not solve the problem.Actually i am reading the file from http service and then storing the result in xmllistcollection. Now i have to iterate over this xmllistcollection rather than over the tree.PFB the code.
            <mx:HTTPService id="httpid" url="org.xml" resultFormat="e4x"/>
            <mx:XMLListCollection id="xmllistid" source="{httpid.lastResult.person}"/>
            I am trying to do something like this but its not working
            for each(var xml:XML in xmllistid){
                Alert.show(xml.toString());
            Please suggest.
            • 3. Re: how to iterate over a tree
              If you have verified that you have data coming back from the server, maybe this will work:
              Alert.show(xml.toXMLString());
              www.ChikaraDev.com
              • 4. Re: how to iterate over a tree
                harsh_hot Level 1
                Thanks Greg,
                I tried doing that too but of no avail. I am reading from an external file "org.xml" stored locally, via httpservice and then storing it in xmllistcollection.PFB my code
                But it doesnt display anything. Whereas, when i use a <mx:Tree> element it displays the tree perfectly using the following code
                <mx:Tree x="731" y="10" width="198" height="480" id="sampletree" dataProvider="{xmllistid}" labelField="@name"></mx:Tree>
                So it means that data is coming from httpservice and getting stored in xmllistcollection but while traversing it i am getting problems.
                • 5. Re: how to iterate over a tree
                  harsh_hot Level 1
                  I used URLRequest and URLLoader and the problem got solved. I stored the result retrieved from it in a XML variable and then iterated over it.
