2 Replies Latest reply on Jun 9, 2008 7:20 AM by dsdsdsdsd
    scaling models
    dsdsdsdsd Level 1
      hello;
      the scale command only offers scaling along the x,y,z axis's;
      is it possible to scale along some other vector?
      my models are coming from Rhino --> LW --> .w3d;
      within the w3d's, the models ARE NOT aligned/positioned relative to world(x,y,z)/world(0,0,0);
      I can add to my w3d a couple of null points that I can use to establish a scale-axis vector and also scale base point;
      but then what ... does director have a way to scale along a vector relative to some point?
      thanks
      dsdsdsdsd
        • 1. Re: scaling models
          Necromanthus Level 2
          Any other vector can be generated in the XYZ coords performing different scale on each direction.
          But probably you're looking for model scale using a different pivot.
          In this case all you have to do is to create a group, set the desired position & rotation for this group, add the model as child and perform the scale on that group.
          cheers
          • 2. Re: scaling models
            dsdsdsdsd Level 1
            necromanthus, I will give this a try;
            effectively I will:
            - import a model ( in a w3d of course ) and with it I will import 2 null points ( pivot point and direction point for orientation );
            - in director build a group with positioning and orientation based on null points;
            - do the parenting stuff
            - scale group
            thanks
            dsdsdsdsd
