2 Replies Latest reply on Jan 14, 2010 1:26 AM by FogliaLabs
    Send data to Asp.Net
    FogliaLabs
      Hi, I'm new in Adobe Flex. I'm a .Net developer and I need to create a simple Flex application that use Asp.Net to grab data from a SQL Server. To send data from Asp.Net to Flex I use an XML string. Then I insert my data in a Flex DataGrid.
      Now i can change the values in the DataGrid cells.
      The problem is to send back the data to my Asp.Net application for update the database.
      How i can generate a XML string of the data that is in the Flex DataGrid?
      There is a kind of DataSet in Flex?
      Thanks for help!
      Marco
