2 Replies Latest reply on Jan 13, 2010 12:28 PM by pauland
    Targeting objects made at runtime
    Post726 Level 1
      I have placed 500 points on my flex application and want to be able to control them each individually. here is the code that I have so far:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
           <mx:Script>
                <![CDATA[
                     import mx.core.UIComponent;
                     import flash.display.Sprite;
                     import mx.effects.easing.Linear
                     private var arr:Array = new Array;
                     private function init():void
                          for(var i:int = 0; i < 500; i++)
                               arr[i] = i/2;
                          var num:int = arr.length;
                          for(var j:int = 0; j < num; j++)
                               var point:Shape = new Shape();
                               point.graphics.beginFill(0x000000);
                               point.graphics.drawCircle(j, arr[j], 1);
                               point.graphics.endFill();
                               var ui:UIComponent = new UIComponent;
                               ui.addChild(point);
                               ui.id = "p"+j;
                               this.addChild(ui);
           </mx:Script>
      </mx:Application>
      When I try to target any of the points or UIComponents, Flex builder cannot see them because they will be created at run time. How can I target them with something like an animiateProperty tag?
      Ex.
          <mx:AnimateProperty id="moveY" target="{p499}" property="y" toValue="0" fromValue="250" duration="2000" easingFunction="Linear.easeNone"/>
        • 1. Re: Targeting objects made at runtime
          Gregory Lafrance Level 6
          This code provides a workaround:
            <mx:Script>
              <![CDATA[
                private function init():void{
                  for(var i:int = 0; i < 500; i++){
                    arr[i] = i/2;
                  for(var j:int = 0; j < num; j++){
                    ui.addChild(point);
                    ui.name = "p"+j;
                    this.addChild(ui);
            </mx:Script>
            <mx:AnimateProperty id="moveY" property="y" toValue="0"
            <mx:Button click="moveY.play([this.getChildByName('p499')]);"/>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: Targeting objects made at runtime
            pauland Level 4
            add
            private var pArr:Array = new Array();
            add
            pArr.push(point);
            Instead of {p499} use "{pArr[499]}"
            Paul
