3 Replies Latest reply on Jan 13, 2010 1:27 PM by pwindsor
    Functionality Question
    pwindsor Level 1
      Hello,
      I had a question (and it is a newbie question) as to whether or not LiveCycle had the ability to determine what forms a particular field is used on. If I were to create a field to capture the "last name"and then used that field on 15 different forms, is there a way to go to that field and have it list what forms it is being used on?
        • 1. Re: Functionality Question
          pguerett Level 6
          There is nothing inherent in the product that will do that. If you build a fragment that has that field in it you can get a report as to which forms are using that fragment (assuming that you are using LiveCycle Server repository to store the assets). Note that a fragment can have 1-many objects on it.
          Paul
          • 2. Re: Functionality Question
            pwindsor Level 1
            Paul, thanks for the response, now I have a follow-up questions:
            1. Does Adobe Live cycle have a Repositary that we can run report on - which contain the cross reference which contain for each Forms what are the Fragments, templates, master pages, sub forms that are used.
            2. I have the same quesiton for Tags / data Dictionary elements on the Forms? Does Adobe Livecycle store Tags/ Data Dictionary elements on the Forms in some repositary for reference for each form that can be accessed
            • 3. Re: Functionality Question
              pguerett Level 6
              Yes there is a repository on LiveCycle server. It does allow you to see the correlation between fragments and templates. It will not report on the internals of the template (i.e. master pages, subforms individual fields etc). As the templates are all XML based you coudl create a system where when you store a  template in teh repository that it is interrogated and all aspects that you want to track are stored in a DB. Then you coudl run reports on the data in teh DB.
              function(){return A.apply(null,[this].concat($A(arguments)))}
              No it does not ...you coudl expand teh DB idea to include these types of elements.
              If you are interested in pursuing these types of questions you should be speaking to an account manager and an SE.
              Paul
