2 Replies Latest reply on Jan 14, 2010 9:35 AM by David Brannan
    Cannot access binded variable inside a resultEvent
    David Brannan
      Hello from Alaska - it was only -47 F this morning.
      I'm adding a flex multi-file uploader to my application and ran into a sticking point (going on 3 days now), and I hope someone with a kind heart and more IQ points than I was blessed with can help.
      In order to upload files to a CF uploader I am passing in two variables (jsessionID + myQuestionID).
      This all takes place in a function as follows:
      // initUploader is called when account info loads
      public function getSessionInfoResult(event:ResultEvent):void{
      // Get jsessionid & questionid (final directory) for CF uploader
      myToken = roAccount.getSessionToken.lastResult;
      myQuestionID = questionsDG.selectedItem.QuestionID;
      var postVariables:URLVariables = new URLVariables();
      postVariables.jsessionid = myToken;
      postVariables.questionid = myQuestionID;
      multiFileUpload = new MultiFileUpload(
                      filesDG,
                      browseBTN,
                      clearButton,
                      delButton,
                      upload_btn,
                      progressbar,
                      uploadDestination,
                      postVariables,
                      350000,
                      filesToFilter
      multiFileUpload.addEventListener(Event.COMPLETE,uploadsfinished);
      I've set myQuestionID as a public binded variable at the top of my actionscript block as follow:
      [Bindable]
      public var myQuestionID:int;
      I can see myQuestionID elsewhere in my form, but not inside the getSessionInfoResult function.
      No matter how I try to bind it - private, public, create it's own function, it just won't show up in getSessionInfoResult.
      Any ideas out there would sure be appreciated.
        • 1. Re: Cannot access binded variable inside a resultEvent
          Gregory Lafrance Level 6
          This code shows it is visible within the result handler. Something else must be wrong with your code.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            creationComplete="svc.send();">
            <mx:Script>
              <![CDATA[
                import mx.rpc.events.ResultEvent;
                [Bindable] public var myQuestionID:int;
                  myQuestionID = 59355;
            </mx:Script>
            <mx:HTTPService id="svc" url="http://www.google.com"
              result="getSessionInfoResult(event);" resultFormat="text"/>
            <mx:Text text="{myQuestionID}"/>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: Cannot access binded variable inside a resultEvent
            David Brannan Level 1
            Hello Greg - thank you for taking a bit of your day to help.
            If I hard code myQuestionID = 59355; into the getSessionInfoResult it is visible (I did that for debuggin ensure my uploader works - and it does).
            However, if I try to bind a selected item from my grid inside getSessionInfoResult - like:
            myQuestionID =questionsDG.selectedItem.QuestionID;
            then it shows a value of null.
            I cannot get myQuestionID =questionsDG.selectedItem.QuestionID; to work anywhere between my action script tags, but it works fine in the form itself.
            Attached is updated code.
