6 Replies Latest reply on Jan 14, 2010 1:18 PM by Wade_Zimmerman
    crop marks
    Rehan ali Level 1
      in illustrator cs4 when i export image with cliping mask the white areas also export with object is there any way to resolve in cs3 i have no problem
        • 1. Re: crop marks
          Jacob Bugge MVP & Adobe Community Professional
          Rehan Ali,
          I believe you should use the Artboard (Tool) in CS4 to defined the boundaries of Export.
          • 2. Re: crop marks
            Rehan ali Level 1
            thanks i used this tool to artboard to define the boundries of my work i have to work alot to do that is there any other way to handle my artwork plz
            • 3. Re: crop marks
              As far as I remember, when you DoubleClick the Artboard Tool there is a option Crop to Artwork or something like that.
              • 4. Re: crop marks
                shunithD Level 3
                It looks right to me... the crop marks are lined up with the edges...  s/he has curved corners... there's bound to be white around the curved areas...
                • 5. Re: crop marks
                  It depends how you interpret the image. I was in doubt, but ended up assuming that issue was the white part on all sides; if it was just at the roundings I wonder how it could be fine in CS3.
                  I hope we shall know.
                  • 6. Re: crop marks
                    Wade_Zimmerman Level 6
                    When exporting the file as an image file format then uncheck use art boards.
                    you get this
                    or this when opened in Photoshop as a jpeg
                    or when placed as a transparent png in a photoshop file.
                    So uncheck use artboards, keep in mind when opening in Photoshop it is perhaps best to place it in a transparent photoshop document if you want to see easily and instantly see the shape has a transparent background. File formats that do not support transparency like jpeg will not have a transparent background.
