1 Reply Latest reply on Jan 15, 2010 10:12 PM by Jadware
    flex to add email to sql
      can i use flex to add a email to a mySql database i see lots of tutorials on how to get data from a mysql but none to add to it?
        • 1. Re: flex to add email to sql
          Flex is only one piece of the puzzle in this case.  You're going to need a mechanism on the server-side to mitigate communication between Flex and SQL, like Java, PHP, .NET, etc.  Now you can modify one of the examples you've seen to do an INSERT or UPDATE SQL statement instead of SELECT and accomplish the goal that way.  Look at some of the documentation regarding "Data Services" in Flex.  Bottom line, you're going to need more than just a Flex swf to send and retrieve data from your server.
