3 Replies Latest reply on Jan 15, 2010 12:39 AM by Sebastien V.
    Can't add eventListener to fileReference
    vital_101
      Hey everyone,
      I'm trying to simply add an eventListener to a fileReference, yet Flex keeps telling me: "Access of undefined property fileRef"  and "Access of undefined property selectHandler".
      Here's the code.
      import flash.net.FileReference;
      var fileRef:FileReference = new FileReference();
      fileRef.addEventListener(Event.SELECT, selectHandler);
      private function selectHandler(event:Event):void {
           mx.controls.Alert.show("hello!");
      Any help would be greatly appreciated.
        • 1. Re: Can't add eventListener to fileReference
          Sebastien V. Level 3
          The call
          needs to be in a method, you can't just drop it in the middle of the class you're using.
          Use the constructor for an AS3 class or the creationComplete event in a mxml file.
          • 2. Re: Can't add eventListener to fileReference
            vital_101 Level 1
            Going with what you said about the fileReference creation needing to be in a method, I dropped it in the 'browseFile' method and I didn't get errors this time.  However, after I select the file the 'selectHandler' method isn't launched.  The proper use of the selectHandler would be to start the upload of the file to the server no?  So shouldn't a simple alert box pop up without any problem?
            [CODE]
            <mx:Script>
                        <![CDATA[
                            //var fileTypes:Array = new Array();
                            //var imageTypes:Object = new Object();
                            public function browseFile():void {
                                fileRef.browse();
                    </mx:Script>
                    <!-- Start Image Upload Stuff -->
                    <!-- On click, execute actionscript for file upload dialoug -->
                    <mx:FormItem label="Upload Image" fontWeight="bold" fontSize="11" width="402">
                        <mx:Button click="browseFile()" label="Browse" fillAlphas="[1.0, 1.0]" fillColors="[#FBFBFB, #C8C7C7]" width="100" themeColor="#638DA8" color="#4E585A" fontWeight="normal"/>
            [/CODE]
            • 3. Re: Can't add eventListener to fileReference
              Try to change to scope of your fileRef to a class variable, instead of a method internal variable.
              Code :
              <mx:Script>
                          <![CDATA[
                                  fileRef = new FileReference();
                                  fileRef.browse();
               </mx:Script>
              etc...
