0 Replies Latest reply on Jan 14, 2010 8:42 AM by Paul Reilly
    [svn:fx-4.0.0] 13503: * Fixed two issues seen in FB.
    Paul Reilly Level 1
      Revision: 13503
      Revision: 13503
      Author:   preilly@adobe.com
      Date:     2010-01-14 08:41:58 -0800 (Thu, 14 Jan 2010)
      Log Message:
      • Fixed two issues seen in FB.
      QE notes:
      Doc notes:
      Bugs: SDK-24938, SDK-24708
      Reviewer: Darrell
      Tests run: checkintests, junit oem
      Is noteworthy for integration: yes, these fix FB issues
      Code-level description of changes:
        tools/oem/Application.java
          Modified getReport() to pass the SourceList into the OEMReport constructor.
        tools/oem/Library.java
          Modified compile() and recompile() to pass the
          CompilerConfiguration into processSources().
          Modified processSources() do token expansion on "sources" before
          processing.
        tools/oem/internal/OEMReport.java
          Modified constructor to take an additional SourceList arg and to
          use it to initialize sourceListPaths.
          Modified processSources() to no longer initialize sourceListPaths
          because the constructor now does it.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24938
          http://bugs.adobe.com/jira/browse/SDK-24708
      Modified Paths:
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
