3 Replies Latest reply on Jan 14, 2010 11:56 AM by Junk Mailer
    File Saving Issue
      All yesterday I noticed an issue that has never occurred before. Whenever I save, save as or export, I get a pop-up that says "Replace Files" and it lists the files in the directory. Then if I select replace, it replaces the file, but also saves another one with a -01 after the filename. (Example: filename.eps and filename-01.eps) Normally, I hit ctrl+s and it just saves. Now it does this replace file thing every time. Additionally, it does the same thing when I save as PDF, or export to JPEG. Is this something that I can turn off? I couldn't find it in preferences or anything. I've attached a pic of the message.
      Any help is appreciated. Thank you.
