0 Replies Latest reply on Oct 10, 2006 7:57 AM by calmchess333
    in need of serious help
    calmchess333
      I am using the following RSO code in an attempt to store data in an RSO and then use the stored data in a if else statement ....so lets say I stored the number 1 in a variable called var0 [code]var0 = "1";)[/code].....then i want to store var0 in anRSO.
      Then I want to use the data which is stored in the RSO as the conditional parameter in an if else statement [code]if (var0 <=1){some action}else{some other action}[/code]
      My problem is I cannot store a variable or a string or use a object on stage to store data.
      How do I change this code so that I can store and use any data held in a variable which exsists someplace within my script?
      How do I change this code so that I can store and use data from any object on stage?
      How do I change this code so that I can use the data stored in the rso in an if else statement?
      Here is the rso code.
